First post, by Exploit
When i try to link some object files with WLINK.EXE i get the following error message:
Error! E3033: directive error near
That is my code:
ONE.ASM
; PROG ONE.ASM
EXTRN TWO:FAR
.MODEL SMALL
.STACK 256
.CODE
MAIN:
MOV AH, 00
MOV DL, 34h
MOV AH, 02h
INT 21h
CALL TWO
MOV AH, 4Ch
INT 21h
END MAIN
TWO.ASM
; PROG: TWO.ASM
PUBLIC TWO
.MODEL SMALL
.STACK 256
.CODE
TWO PROC FAR
PUSH BX
PUSH CX
MOV DL, 32h
MOV AH, 02h
INT 21h
POP CX
POP BX
RET
TWO ENDP
END
JWASMR.EXE does assemble the code without errors to obj files.
The -0 option is for 8086.
C:\>jwasmr -0 one.asm two.asm
JWasm v2.14, Dec 20 2020, Masm-compatible assembler.
Portions Copyright (c) 1992-2002 Sybase, Inc. All Rights Reserved.
Source code is available under the Sybase Open Watcom Public License.
ONE.ASM: 18 lines, 2 passes, 0 ms, 0 warnings, 0 errors
TWO.ASM: 19 lines, 2 passes, 0 ms, 0 warnings, 0 errors
C:\>dir *.obj
ONE.OBJ
TWO.OBJ
But WLINK.EXE can't link them:
C:\>wlink one.asm two.asm
Open Watcom Linker Version 1.9
Portions Copyright (c) 1985-2002 Sybase, Inc. All Rights Reserved.
See http://www.openwatcom.org/ for details.
Error! E3033: directive error near 'one.asm'
C:\>
I also tried
wlink one.obj two.obj
but this didn't help either.
It might be possible, that wlink needs other paramters, but the linker command example (ot the code) is from a book that is written for MASM
and there it says i have to use:
ML  CODE1.ASM CODE2.ASM
Thus i tried to adapt to WLINK.EXE but without success.
Reply 1 of 9, by Exploit
Okay, i solved it.
WLINK.EXE does need different parameter options:
In this example it works with the following command line:
wlink name test.exe format dos file one.obj , two.obj
The "name" options followed by a file name defines how the resulting executable should be called.
TEST.EXE can be changed to whatever you want to use and is the resulting executable name.
The "format" option followed by "DOS" defines, that this is an executable for DOS.
The "file" option followed by an object file, that was created with JWASMR defines what obj files to use.
Each object file must be separated with a comma.
The linker seems to not be able to use *.asm code files and pass them to jwasmr automatically.
Reply 2 of 9, by pan069
Try this:
wlink name final.exe file one.obj,two.obj
Note the comma between the object files.
Edit: You beat me to it. 😀
Reply 3 of 9, by Exploit
pan069 wrote on 2022-08-21, 09:45:
Try this: […]
Try this:
I also found out, that it is not required to add the file extension.
This:
wlink name final file one,two
will work too. At least in DOS, it might be different on other systems but i need wlink only for DOS.
The file extension is automatically determined.
Reply 4 of 9, by Ringding
Why do you create a FAR proc when using model SMALL?
Reply 5 of 9, by Exploit
Ringding wrote on 2022-08-21, 12:50:
Because it's in another object file and thus very likely another segment.
Reply 6 of 9, by mkarcher
Exploit wrote on 2022-08-21, 12:55:
The idea of MODEL SMALL is that the code segments of all source files gets combined by the linker into a single 64K code segments, so all CALLs and function pointers can be near. If you want different code segments for different object files, you should use MODEL MEDIUM (near data pointers) or MODEL LARGE (far data pointers). Even in MODEL LARGE, all data segments from the object files get combined into a single data segment, and DS is intended to point to this "primary data segment". Standard data pointers are allowed to point anywhere, even outside of the primary data segment. (e.g. segments allocated from DOS using INT 21h/AH=48h, video memory or the EMS page frame).
Reply 7 of 9, by Exploit
mkarcher wrote on 2022-08-21, 13:39:
Well, I was just repeating what's in the book. And it seems to make sense for library purposes.
Reply 8 of 9, by BloodyCactus
Exploit wrote on 2022-08-21, 09:04:
But WLINK.EXE can't link them: […]
C:\>
well, you cant link assembler files before assembling them... and as you noted, wlink has a formatted command line. easier to just wcl/wcl386 if you want one step compile+link.
Reply 9 of 9, by Exploit
BloodyCactus wrote on 2022-08-21, 14:58:
That was not the point. I also said, i used wlink *.obj ... etc.
And ml.exe can do exactly that. It assembles and links in one go.
Also you're too late, the problem is already solved.
