Dos 6 conventional memory tricks
Reply 280 of 298, by iraito
Jura Tastatura wrote on 2022-08-27, 11:03:
I would also try to use UMBPCI if you have supported chipset.
Ok, i was able to get a bit of memory, i would like to use SHCDX but i can't find a decent guide anywhere.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
Reply 281 of 298, by Nemo1985
iraito wrote on 2022-08-27, 12:54:
It doesn't need anything special, just a line on the autoxec bat:
That's what I use: C:\UTIL\SHSUCDX.COM /D:OPTICAL
Reply 283 of 298, by ssokolow
iraito wrote on 2022-08-27, 14:26:
It tells me that SHSUCDX can't open CD driver optical
That was an example of what they use. You need to use the same CD drive identifer you're currently feeding to MSCDEX. (/D:MSCD001 rather than /D:OPTICAL)
The /D:mscd001 on your oakcdrom.sys line in config.sys creates the name and then the /D:mscd001 on your MSCDEX or SHSUCDX connects to it.
Internet Archive: My Uploads
My Blog: Retrocomputing Resources
My Rose-Coloured-Glasses Builds
I also try to announce retro-relevant stuff on on Mastodon.
Reply 284 of 298, by iraito
ssokolow wrote on 2022-08-27, 14:29:
in config i have:
devicehigh=C:\cdrom\oakcdrom.sys /D:mscd001
In autoexec
LH C:\CDROM\SHCDX\SHSUCDX.COM /D:mscd001
Still not working
Reply 286 of 298, by ssokolow
Another thing you could try.
If your COMMAND.COM is taking more than 816 bytes of conventional memory, setting 4DOS 8.00 (the "Free 4DOS" link at https://www.4dos.info/v4dos.htm#751 ) as the shell= can give you tab completion, command history, and a bunch of other nice stuff while also freeing up some conventional memory, thanks to its "XMS Swapping" feature.
Reply 287 of 298, by azaar95
This is why I like forum platforms that allow you to have the post reply included in the email notification--so you know if it's spam before you even head to the forum.
Reply 288 of 298, by Ensign Nemo
Hi guys,
I've been playing around with Windows 98 on an HP T5710 thin client and would appreciate some feedback on the DOS side of things. I've been able to free up 602K of conventional memory using a basic setup similar to some of the examples here. One thing that been bugging me is that I'm seeing COMMAND loaded twice when I run "mem /c ":
MEM /C
Modules using memory below 1 MB:
Name Total Conventional Upper Memory
SYSTEM 37,712 (37K) 9,568 (9K) 28,144 (27K)
HIMEM 1,168 (1K) 1,168 (1K) 0 (0K)
EMM386 4,320 (4K) 4,320 (4K) 0 (0K)
DBLBUFF 2,976 (3K) 2,976 (3K) 0 (0K)
COMMAND 10,144 (10K) 0 (0K) 10,144 (10K)
CTMOUSE 3,552 (3K) 0 (0K) 3,552 (3K)
VIAFMTSR 38,960 (38K) 0 (0K) 38,960 (38K)
IFSHLP 2,864 (3K) 0 (0K) 2,864 (3K)
COMMAND 6,976 (7K) 0 (0K) 6,976 (7K)
Free 635,104 (620K) 616,656 (602K) 18,448 (18K)
Memory Summary:
Type of Memory Total Used Free
Conventional 634,880 18,224 616,656
Upper 109,088 90,640 18,448
Reserved 0 0 0
Extended (XMS)* 250,435,040 759,264 249,675,776
Total memory 251,179,008 868,128 250,310,880
Total under 1 MB 743,968 108,864 635,104
Total Expanded (EMS) 33,931,264 (32M)
Free Expanded (EMS)* 33,554,432 (32M)
* EMM386 is using XMS memory to simulate EMS memory as needed.
Free EMS memory may change as free XMS memory changes.
Largest executable program size 616,640 (602K)
Largest free upper memory block 13,008 (13K)
MS-DOS is resident in the high memory area.
Here is the more detailed "MEM /d" output:
MEM /d
Conventional Memory Detail:
Segment Total Name Type
00000 1,024 (1K) Interrupt Vector
00040 256 (0K) ROM Communication Area
00050 512 (1K) DOS Communication Area
00070 1,424 (1K) IO System Data
CON System Device Driver
AUX System Device Driver
PRN System Device Driver
CLOCK$ System Device Driver
A: - C: System Device Driver
COM1 System Device Driver
LPT1 System Device Driver
LPT2 System Device Driver
LPT3 System Device Driver
CONFIG$ System Device Driver
COM2 System Device Driver
COM3 System Device Driver
COM4 System Device Driver
000C9 5,120 (5K) MSDOS System Data
00209 9,568 (9K) IO System Data
1,152 (1K) XMSXXXX0 Installed Device=HIMEM
4,304 (4K) EMMXXXX0 Installed Device=EMM386
2,960 (3K) DblBuff$ Installed Device=DBLBUFF
544 (1K) Sector buffer
512 (1K) BUFFERS=40
0045F 80 (0K) MSDOS System Program
00464 224 (0K) MEM Environment
00472 90,464 (88K) MEM Program
01A88 526,192 (514K) MSDOS -- Free --
Upper Memory Detail:
Segment Region Total Name Type
0B15C 1 8,624 (8K) COMMAND Program
0B377 1 80 (0K) COMMAND Data
0B37C 1 1,440 (1K) COMMAND Environment
0B3D6 1 224 (0K) MSDOS -- Free --
0B3E4 1 3,552 (3K) CTMOUSE Program
0B4C2 1 240 (0K) VIAFMTSR Environment
0B4D1 1 13,008 (13K) MSDOS -- Free --
0CC01 2 30,992 (30K) IO System Data
2,848 (3K) IFS$HLP$ Installed Device=IFSHLP
464 (0K) Block device tables
2,080 (2K) FILES=40
256 (0K) FCBS=4
21,440 (21K) BUFFERS=40
704 (1K) LASTDRIVE=H
3,072 (3K) STACKS=9,256
0D392 2 38,720 (38K) VIAFMTSR Program
0DD06 2 5,536 (5K) COMMAND Program
0DE60 2 1,440 (1K) COMMAND Environment
0DEBA 2 5,216 (5K) MSDOS -- Free --
Memory Summary:
Reserved 0 0 0
Handle EMS Name Size
0 05C000
Memory accessible using Int 15h 0 (0K)
XMS version 3.00; driver version 3.95
EMS version 4.00
I assume that COMMAND.COM is being loaded twice? While it's not eating conventional memory, I'd still like to know why this is happening and if it could cause any problems (I'm trying to learn how this stuff works, not just how to use it). I'm booting into DOS using a PIF file created by making a shortcut to COMMAND.COM in my Windows directory. Here is the CONFIG.SYS part of it:
DOS=HIGH,UMB
FILES=40
BUFFERS=40
LASTDRIVE=H
DEVICE=C:\windows\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\windows\EMM386.EXE RAM I=B000-B7FF
Here is the AUTOEXEC.BAT part:
SET TEMP=C:\TMP
SET PATH=C:\WINDOWS;C:\WINDOWS\COMMAND
LH C:\DRIVERS\CTMOUSE.EXE /R2
SET BLASTER=A220 I7 D1 P0 J0
LH C:\DRIVERS\SOUND\VIASBCFG
LH C:\DRIVERS\SOUND\VIAFMTSR
I've tried removing various lines and it still occurs each unless I remove the "DOS=HIGH,UMB" part.
I apologize if this is a simple question. I wasn't able to find anything in the forum or online.
Thanks in advance!
Reply 289 of 298, by ssokolow
Ensign Nemo wrote on 2022-11-15, 05:59:
Huh. You're right. I avoided having to reboot into MS-DOS Mode if at all possible as a kid and, as an adult, I use the boot menu that came with my copy of PartitionMagic 3 and dual-boot Windows 98SE and DOS 6.22+Windows 3.11 for Workgroups, so I never noticed.
Anyway, it looks like it's because, when you ask to launch COMMAND.COM as the application, it takes you at your word and doesn't do anything fancy to collapse away the COMMAND.COM you get as part of DOS, leaving you with a nested COMMAND.COM session.
If you're familiar with Linux command-line stuff, it'd be sort of like a launcher GUI using bash -c "$1" to process a user-specified command-line . If the user specifies bash as the command, then that becomes bash -c "bash", resulting in a nested bash.
You can test this by creating a test.bat file containing something like this and then creating an MS-DOS Mode PIF for that instead:
mem /c /p
pause
That'll get you a mem /c /p readout without first invoking a nested COMMAND.COM
One option to resolve the issue is to attrib -r c:\msdos.sys, then edit msdos.sys and then change the BootGUI=1 line to BootGUI=0 so it won't boot into the GUI until you type win, leaving you running at that initial COMMAND.COM. (As of Windows 95, msdos.sys changed from machine code to a config file.)
Alternatively, you could do the fun thing and use edit, echo, Alt+219 (keypad numbers only), CHOICE.EXE, and ERRORLEVEL to create your own one-touch batch-file menu for your MS-DOS Mode shortcut to invoke instead of COMMAND.COM.
(In fact, using batch files to control the top-level COMMAND.COM is how fancy GUI menus for DOS avoid stealing memory from the things they launch. You run a batch file, the batch file launches the GUI menu EXE, and the GUI menu EXE rewrites another batch file with your choice before exiting, which the top-level batch file will invoke after it exits so it can ask COMMAND.COM to run something after it's exited and freed the memory. Then, the batch file it wrote loops back around to the main one when it completes.)
Reply 290 of 298, by Ensign Nemo
Thanks for the help!
ssokolow wrote on 2022-11-15, 06:40:
If you're familiar with Linux command-line stuff, it'd be sort of like a launcher GUI using bash -c "$1" to process a user-spec […]
mem /c /p
pause
I tried that. When I run the pif from Windows, it bluescreens on me. However, after powering off and on again, it runs the script. You're right, it doesn't load it a second time!
This works, but I lose the autoexec.bat and config.sys settings from the PIF file. I assume that I would need to create a new autoexec.bat and config.sys in the c:\ root?
Thanks, could you please clarify how to do this? Do you mean that I should edit my PIF file from Windows 98?
Reply 291 of 298, by Ensign Nemo
I just created an autoexec.bat and config.sys in the root of c, so that assumption was correct. I only end up with a single command.com loaded in memory too!
Reply 292 of 298, by ssokolow
Ensign Nemo wrote on 2022-11-15, 07:25:
I meant customizing/creating autoexec.bat and config.sys like you did, then creating a file like this with a name like menu.bat, then starting it from autoexec.bat:
@echo off
:TOP
cls
echo.
echo ████████████████████
echo █ Main Menu █
echo █ 1. Thing One █
echo █ 2. Thing Two █
echo █ 3. Thing Three █
echo █ W. Start Windows █
echo █ X. Exit Menu █
choice /C:123WX /N
cls
IF ERRORLEVEL 5 GOTO END
IF ERRORLEVEL 4 GOTO WIN
IF ERRORLEVEL 3 GOTO THING3
IF ERRORLEVEL 2 GOTO THING2
IF ERRORLEVEL 1 GOTO THING1
GOTO TOP
:THING1
echo Replace me with the command for Thing One
pause
GOTO TOP
:THING2
echo Replace me with the command for Thing Two
pause
GOTO TOP
:THING3
echo Replace me with the command for Thing Three
pause
GOTO TOP
:WIN
win
GOTO TOP
:END
...or, if you want to get fancy and use characters where I don't have the Alt+ code burned into my memory, something like this:
@echo off
:TOP
cls
echo.
echo ╔══════════════════╗
echo ║ Main Menu ║
echo ╠══════════════════╣
echo ║ 1. Thing One ║
echo ║ 2. Thing Two ║
echo ║ 3. Thing Three ║
echo ╟──────────────────╢
echo ║ W. Start Windows ║
echo ║ X. Exit Menu ║
echo ╚══════════════════╝
choice /C:123WX /N
cls
GOTO TOP
:THING1
pause
GOTO TOP
:THING2
pause
GOTO TOP
:THING3
pause
GOTO TOP
:WIN
win
GOTO TOP
:END
(I got lazy, so I just wrote that on my Linux PC in gVim by copy-pasting characters from the Wikipedia "Code page 437" article, used set fenc=cp437 to save in the correct encoding, and then tested in DOSBox.)
Reply 293 of 298, by Ensign Nemo
Thanks again for the advice! I'll try this later when I get home from work. I have a couple of questions.
1. Is there a reason why you are calling menu.bat from autoexec.bat rather than creating the menus in autoexec.bat and config.sys? A lot of people here are using the menu system described by the Phil's Computer Lab guy. They don't call any external files. For me, I wanted to start with something simpler. If I encounter any problems, I can always add menu items later.
2. Under the menu sections (THING1, THING2, THING3), does the regular autoexec stuff go in there? Like would I put the Sound Blaster settings in there?
3. Do you know if setting up an autoexec.bat and config.sys this way affect Windows at all? Previously, I just had the PIF file for DOS mode. If I switch to using the bootgui=0, along with an autoexec.bat and config.sys, would the computer get setup with the DOS stuff before I use win to start Windows or does it get unloaded?
Thanks again for your help and patience. I appreciate it.
Reply 294 of 298, by ssokolow
Ensign Nemo wrote on 2022-11-15, 19:55:
So that if you press X to exit the menu to the prompt, you can type menu to get back into it without restarting your computer or re-running your autoexec.bat stuff.
No, that'd be the DOS applications you'd normally launch from Windows icons, so you can conveniently exit one application and start another.
If you want multiple config.sys and autoexec.bat configurations in this paradigm, you use the MENU... config.sys statements introduced with MS-DOS 6.x and then have your autoexec.bat switch behaviour based on the value of %CONFIG% as explained here or here.
(My approach to DOS, even back in the days when I was a kid, was to not accept "you need multiple CONFIG.SYS configurations for different purposes" as an answer until I'd exhausted every other option, because restarting the computer was annoyingly slow and I wanted to avoid restarts whenever possible. These days, thankfully, there's plenty of freeware like 4DOS, ANSIPLUS, UIDE, SHSUCDX, CuteMouse, etc. that can leave tons of conventional memory free and provide richer functionality than I ever had as a kid.)
It'll stay there, aside from a few bits like himem.sys which Windows knows how to take over from, because Windows 9x uses MS-DOS as the 16-bit driver compatibility layer. Depending on what you plan to put in your config.sys, it may be best to have separate DOS and Windows options in that config.sys MENU... setup I linked to.
Reply 295 of 298, by froller
This will help
DEVICE=C:\WINDOWS\emm386.exe  D=64 I=B000-B7FF I=C800-EFFF FRAME=C800 RAM
If you have cards with OPTROM installed then use UMBINFO.COM to determine where their ROMs are located and exclude it from arguments for EMM386.EXE.
▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ 100%
Virus check complete. All viruses are working properly.
Reply 296 of 298, by Samir
froller wrote on 2024-02-12, 00:41:
This will help […]
This will help
This is actually very important and I didn't remember that I would specify exclusions and inclusions to completely manually tell emm386 and himem exactly what regions to use and avoid.
Reply 297 of 298, by wierd_w
I usually use MSD to look at >1Mb memory, to see if it is occupied.
More than option roms can be in the option rom region these days, and silly things can happen if they get mapped out. If there is data there, I try to exclude it until I know what that data is for.
In some cases, the option rom is useless to DOS, such as pxe bioses. Forcing an INCLUDE will basically unmap it, and free it for umb use.
Reply 298 of 298, by froller
I usually include everything and then watch with UMBINFO if it is used by and then exclude.
