200W AT power supply
First post, by dennisE
Very good guys,
With a 200w AT power supply, how many devices can I power?
Thanks very much!!
Reply 2 of 12, by Lylat1an
The power supply should have a sticker showing the power ratings for each rail.
Devices like hard drives typically show how many amps they draw as well.
If you're unsure, Athena Power still makes 400w AT PSUs today. 😜
Reply 3 of 12, by dennisE
Hi Vogons!
For 486 with a sound card, a 250 mb hard drive, two floppy drives, one 5 1/4 and the other 3 1/2, and a CD-ROM. it's too much?
Very Thanks!
Reply 5 of 12, by Lylat1an
lti wrote on 2022-09-17, 02:46:
200W is more than enough for that.
Lylat1an wrote on 2022-09-16, 13:09:
The 300W is a "gutless wonder" (at least the one that was taken apart on Tech Tangents), so I wouldn't trust the 400W.
I use their 400w in my Retro Rig.
Definitely overkill for my purpose, but my only complaint is the loud fan.
Reply 6 of 12, by Romain
From the first glance we see that the quality assembly is of ths bloc is correct, but that the components are of poor or very poor quality...
Perhaps a refurbished or well restored AT power supply from the 90's would be more reliable than this new power supply.
Reply 7 of 12, by matze79
Lylat1an wrote on 2022-09-17, 14:18:
Be sure to use a DC-DC based ATX PSU then, or you may end up with weird results
Modern PSU focus on 12V Power. But most Retro PCs need plenty of 5V. (Slot1/A/Sockel A etc)
Reply 8 of 12, by Lylat1an
matze79 wrote on 2022-09-17, 16:25:
That's why I bought the Athena, I wanted to be sure there was enough 5v, -5v, and 12v power for the AT motherboard and peripherals.
I'd happily buy an ATX2AT converter, but I don't know where to get one...
Reply 11 of 12, by Sphere478
Lylat1an wrote on 2022-09-19, 17:37:
matze79 wrote on 2022-09-19, 08:09:
https://www.ebay.de/itm/132907860793
Well, there a lot on Amazon, Ebay etc.
Not the adapters, this converter: https://x86.fr/atx2at-smart-converter/
I have one of those. I have trouble running it on 586 class computers with a lot of cards.
It is more for 486 and older I gather. But it is super cool and handy.
Sphere's PCB projects.
Reply 12 of 12, by matze79
Ah its not really a Adapter.
This is a circuit breaker basicly.
I run all my Machines with ATX Powersupplys today.
i grabbed few from Dell Vostro Machines (LiteOn / Delta ) with 300Watts.
Just cut down SATA Connectors and added 5,25/3,5" Harddrive/Floppy Power Connectors.
Modern ATX PSU often only deliver 10-15A on 5V.
