First post, by Benji
I pulled the heatsink off a memory controller chip (P4P800-e deluxe) and noticed this underneath. Board runs fine with no apparent damage but I definitely don't want to put it back on like this. The thermal seating pad has corroded or burned off at the edge. I was considering how to replace the pad but don't know how to go about doing this exactly. I checked the internet briefly and don't see where I can easily replace this whole heatsink without it coming off another motherboard. Any suggestions or advice
Thanks
Reply 1 of 2, by Sphere478
Razor at low angle. Then a new pad or some paste.
That stuff around the outide is a shim to keep it level. It would be nice to replace it also, but four dabs of silicone on corners of package would do the same thing. (Maybe better)
Sphere's PCB projects.
Reply 2 of 2, by Benji
Okay makes sense. Wasn't sure how critical it was to replace that pad. Using some paste sounds like a better option. Thanks.
