First post, by Windows9566
I just got this ASUS CUSL2 v1.2 motherboard, but unfortunately the 2nd ram slot won't work no matter what modules i put in. it does post though. none of the capacitors look bad.
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
Reply 1 of 12, by Nexxen
Windows9566 wrote on 2022-09-27, 21:55:
If you plug in a module it doesn't recognize it.
Are there any bent pins inside the ram slot?
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 2 of 12, by Windows9566
Nexxen wrote on 2022-09-27, 21:59:
nope, seems good, don't see any bent pins
Reply 3 of 12, by Windows9566
i tried everything under the sun, cleaning the ram slots using 91% IPA, different modules, etc. nothing seems to change, still only the DIMM1 slot detecting modules.
Reply 4 of 12, by darry
How much RAM are you trying to install in total ? The 815E chipset on that board is limited to 512MB max in total.
If the first slot has a 512MB DIMM installed, you will never get anything to work in the second slot.
Reply 5 of 12, by Windows9566
256 mb (2x 128mb) but only 128mb is working
Reply 6 of 12, by Horun
Have you tried the third slot ?
Reply 7 of 12, by darry
Windows9566 wrote on 2022-09-28, 00:37:
Then why not get a single 512MB DIMM and call it a day ?
You won't need more than one slot then.
Reply 8 of 12, by Nexxen
Checked for solder joints?
Continuity on each ram pin?
Could be a bad connection with the chipset; a broken trace somewhere, a broken smd...
----> this is time consuming
It's a really boring issue, if you want to find the cause, ok, I understand; otherwise move on with slot 1&3 and live happily.
Reply 9 of 12, by Windows9566
i just ended up getting a new CUSL2, but it's the -C version, it works nicely and all the ram slots function.
Reply 10 of 12, by Nexxen
Windows9566 wrote on 2022-10-05, 17:23:
You could try to troubleshoot the other board.
Reply 11 of 12, by Windows9566
im happy with my CUSL2-C, may just use my regular CUSL2 as a scrap board.
Reply 12 of 12, by darry
Windows9566 wrote on 2022-10-08, 21:06:
If the only thing wrong with the board is a single one of the 3 DIMM slots, there is no actual practical functional issue .
This board can only detect and use 512MB of RAM due to a chipset limitation and this can be provided with a single 512MB DIMM, if desired . The only reason the manufacturer likely even bothered to put in 3 DIMM slots was to allow people to use multiple smaller capacity cheaper DIMMs, but this is no longer significant as a single 512MB SDRAM DIMM is now cheap as chips .
If you want to scrap it for parts, it's your choice as you own it, but I personally see that as wasteful as you could still use the board as a a spare or sell it, or give it away (if so inclined) to someone .
