Toshiba DVD decoder card - manual needed
Reply 20 of 26, by Babasha
Meatball wrote on 2022-09-20, 12:17:
Babasha wrote on 2022-09-20, 10:46:
Drivers (ver. 1.01 and 2.01), support software and Toshiba Media Player 1.5
This is Windows 95 only drivers/software for VERSION 1 of Toshiba PCI DVD decoder card!!!
Awesome! Where did you find these?
Ver. 1.01 from floppies with my card
Ver. 2.01 and other stuff from the net and Toshiba Tecra7xxDVD notebooks support
Need help? Begin with photo and model of your hardware 😉
Reply 21 of 26, by Babasha
Ideal compatibility with Intel TC430HX Tucson motherboard!
Fresh install of Win98 and you have working video, sound and Yamaha midi wavetable, DVD video.
NUSB3 update for USB drives support.
Reply 22 of 26, by Babasha
1. Format
Its a NTSC only! Use just NTSC discs and TV-out in NTSC format only
2. Connectors
Back (from top to down): SVHS, composite TV-out (NTSC), analog audio (ch. 1), analog audio (ch. 2), digital audio (AC-3)
PCB audio - usual audio-output (with the channels on sides and two grouns in the middle). You can use CDROM audio cable for connection to your audiocard.
PCB feature connector - first 26 pins for 8-bits feature connector cards/cables (ATI, S3), first 34 pins for 16-bits feature connector/cables (S3). For 16-bits mode connection you can use 34-pin floppy cable WITOUT twist!
PCB connectors pins AFTER the 34-pin are unknown, maybe for “multimedia cases” connection or specialized videocard(s).
3. Windows and videocards compatibility
This TOSHIBA DVD DECODER is compatible with Windows 95, Windowd 98, Windows Me and Windows 2000.
Windows 95 req’s external drivers and proprietary TOSHIBA DVD player (picture IS ALWAYS INTERLACED on computer monitor)!
Windows 98 - 2000 has internal drivers and DVD player compatible with this decoder. Optimal functional and qualitity results achieved with Windows 98.
It req’s videocard with working digital overlay thru feature connector and VPM drives support (ATI Rage||, S3 Virge/DX 375 officialy supported, ATI Rage Pro and S3 Virge 325 compatible too with no warranty of work).
4. Optimal PC configuration
This cards are best for Intel 430HX or 430TH motherboards with Intel Pentium (MMX) CPU, Yamaha ISA 7XX series sound card and S3 Virge/DX or ATI RageII series of videocard. It works “out-the-box” with Intel TC430HX, AN430TX series of motherboards (with onboad S3/ATI videocards and Yamaha soundcards).
Reply 23 of 26, by Babasha
Win95 TOSHIBA MEDIA PLAYER screenshot 😀
Reply 24 of 26, by 386SX
Great! Any info about the player application, has it the same files of a customized Windows DVD sw player or does it look like a real proprietary app?
Reply 25 of 26, by Babasha
386SX wrote on 2022-10-22, 09:36:
Its a Toshiba proprietary app. Nothing like Windows DVD player and its functionality.
Reply 26 of 26, by 386SX
Babasha wrote on 2022-10-22, 11:39:
So I imagine the hardware is used as originally supposed to with all the features and not simply working like I'd expect on such old decoder. Good card indeed.
