First post, by Cobra42898
I have an older (win98) era scanner I have been using to scan older family photos. I decided to use an old gateway p2(celeron) 400C I had lying around for the task. I know that in theory the scanner should be the slowest point in the process, but even just moving large files around can be taxing on these early processors. The good news is, I have recently fixed and made my d815eea2/1.0ghz/133mhzbus system a working machine again. (Yay!) Is it at all likely that the faster ram/bus/cpu will handle USB transfers better than the old 440bx/celeron? Perhaps at least faster transferring files, I would think?
Any thoughts welcome.
Searching for Epson Actiontower 3000 486 PC.
