First post, by moulder
Hi, I'm trying to install Alien Trilogy in Dos mode but it gives mi error that I need 8mb of ram. I've PIII, Fx5500, 2xvoodoo2, s live, 256mb ram , WIN98 and dos mode configured following Phils tutorial. How to ocercome that error?
Reply 2 of 9, by Gmlb256
As DosFreak said, limiting or removing the amount of memory available helps in those situations, try with 64MB RAM at least. Other utilities that can limit the amount of memory like HIMEMX are XMSDSK (a ramdisk driver) and LIMITMEM.
BTW, Alien Trilogy speeds up way too fast on several parts with fast CPUs like the PIII and the GeForce FX 5500 video card won't work well with hi-color mode. At least there is the Throttle utility for slowing down that computer. It isn't perfect, but it works in this case and make sure that the -C command line switch is entered so the CPU cache won't be disabled which would make it way slower than usual. I recommend this variant of Throttle if your motherboard is ASUS branded: link.
Reply 3 of 9, by moulder
Thanks guys for hints. Will try those.
Reply 4 of 9, by moulder
So the problem still exists. Limitmem and Himemx are not warking at all in freedos. But I've found burnmem.sys and its working, limiting my ram to 16MB. Alitn Triloly installer still doesnt work - communicating need of 8MB ram:-(
Reply 5 of 9, by Gmlb256
Try the patch 2.0 of Alien Trilogy: https://www.patches-scrolls.de/patch/298/7/19303
Check the README file, which has the following information:
Fixes.
This patch fixes many problems including incompatibilities with the
following video cards:
Matrox Mystique
Matrox Millenium
Cirrus Logic
Diamond SpeedStar
Diamond Viper
ARK 2000PV (including Diamond Stealth Graphics 2001)
64 megabyte install error
The "64 megabyte install error" fix seems that it will help you. In my case, I only used it after installing the game without a hitch.
Reply 6 of 9, by moulder
Gmlb256 wrote on 2022-12-01, 22:21:
:thinking: […]
Fixes.
Matrox Mystique
Matrox Millenium
Cirrus Logic
Diamond SpeedStar
Diamond Viper
Now, it works. Thank you.
Reply 7 of 9, by Gmlb256
moulder wrote on 2022-12-01, 22:59:
:thinking: […]
Fixes.
Matrox Mystique
Matrox Millenium
Cirrus Logic
Diamond SpeedStar
Diamond Viper
You're welcome!
Reply 8 of 9, by moulder
Is there any solution to.correctly display graphics in 16bit mode on Fx5500? The screen is all green and messy. Only in 256 colors picture is ok.
Reply 9 of 9, by Gmlb256
So far, unfortunately, no. 🙁
I believe that the hi-color mode uses 15bpp which nVidia cards never supported.
