PrintTok-002 for DOS C?
First post, by Harry Potter
Hi! I have a C module for a cross-platform C compiler called printtok-002.c. It is a way to compress strings and print out those strings. Unfortunately, it needs you to manually compress those strings, and it only helped a Commodore 64-based text adventure's text by about 25%. Should I port it to Borland C and Open Watcom C?
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
