Compenstine wrote on 2020-08-28, 16:42:
I tried both the 530 and 620 drivers and all I got was a black screen. They did install and let me change the settings. However, after changing to 256colors and rebooted, Windows wfw 3.11 was running in the background just no picture. This was the same result after trying 7 SiS drivers I had found including the 6326 from the SiS website. I will give jakethompson1's suggestions a try and see what happens. Thank you for the help!
I have a Gigabyte GA-S5MM mobo that I pulled from an old Compaq system (I can't rember the model though) and it has this same chipset/gpu.
I reflashed it to a stock Gigabyte bios from their official site ( though I also forgot to back up the Compaq bios though it was worse in every way due to artificial feature limits and only smaller HDD support) , then I installed DOS 6.22 and Win3.11 WfW and ran into the same issue as Compenstine did.
I did try jakethompson1's suggestions about using "SVGAPatch" and it seems to have worked as I can set it to 1024x768 with 256 colors.
I'm guessing it's purely a driver issue with the SIS 6326 as the options seem correct in their SVGA setup tool but I've tried every option there at "60-75 NI" and all of the failed to show up on my old Dell Ultrasharp 2001FP LCD monitor atleast, though I haven't set up a CRT monitor so it's possible those might work.
If anyone finds out a way to get the SIS drivers working, let me know. 😉
