First post, by Unrealdevon
If you got some noise from your analogue line out can you clean this somehow and then what is the preferred way to it?
Might the connectors be getting old from use?
And yeah im well aware these have noise as it's all analogue. But this is more than it ever was before.
Or is there anything else you should do, like replacing rhe jacks?
My aureal vortex 2 is making some more noise than it used to and I'm certain its the 3.5mm jacks. It's not horrible but before it was more or less quiet.
It's a xitel platinum storm (super quad design)
I have ofcourse muted what i don't need in windows and also don't have any volume sliders maxed out either.
Don't want to do anything to it before asking here first.
Best regards!
Reply 1 of 1, by DundyTheCroc
Spray with some contact cleaner, put in and out 3.5mm jack, rotate it while in.
