First post, by tpowell.ca
I'm having an issue with an Nvidia GeForce GTS I acquired.
The card appears to work just fine with the exception of VGA output.
The problems in short are:
- Ghosting
- Dim luminance, excessive saturation
- Diagonal banding in graphics modes
The card does not have any visible damage, and does not have a DVI output.
I've read that this was a common issue with cards of this era, but no clear mention of any fixes.
Note: I tried different cables and monitors with no effect. Different cards work perfectly fine however.
  • Merlin: MS-4144, AMD5x86-160 32MB, 16GB CF, ZIP100, Orpheus, GUS, S3 VirgeGX 2MB
    Tesla: GA-6BXC, VIA C3 Ezra-T, 256MB, 120GB SATA, YMF744, GUSpnp, Quadro2
    Newton: K6XV3+/66, AMD K6-III+500, 256MB, 32GB SSD, AWE32, Voodoo3
Reply 1 of 5, by darry
tpowell.ca wrote on 2022-01-24, 02:28:
I'm having an issue with an Nvidia GeForce GTS I acquired. The card appears to work just fine with the exception of VGA output. […]
- Ghosting
This discusses sharpness issues due to improperly designed RF filtering on VGA output : http://web.tiscalinet.it/creeping_death/guide/aamodifica.htm
That being said, I am not certain if what is seen on the pictures you shared is related to this or to another phenomenon .
Reply 2 of 5, by pixel_workbench
I have a gf2 gts with exactly the kind of problem you describe. Comparing it with an exact same version that works with a multimeter, I couldn't find anything obvious on the analog output path that would indicate an easy fix, like a broken capacitor or inductor, or noticeably different resistance values. Unless more information becomes available, I would consider that the gpu itself is damaged in this case.
My Videos | Website
P2 400 unlocked / Asus P3B-F / Voodoo3 3k / MX300 + YMF718
Reply 3 of 5, by douglar
I have the same problem with a Virge DX that I found. Other S3 cards display fine on this system. My guess would be failing capacitors, yes? Or would it be a failing clock crystal?
137.86 KiB
281.92 KiB
Reply 5 of 5, by 386DX40
https://www.anandtech.com/show/869/5
Check this old Anandtech article......
Asus A7V8X-LA - Athlon XP 1800+ - 512MB - Geforce FX5200 128MB - SoundBlaster Live - 80GB HDD - Win98SE
DTK PKM-3331Y - Evergreen 5x86 133 - 16MB - WD90C31A 1MB ISA - ESS 1869 ISA - 2.5GB HDD - MS-DOS 6.22
