First post, by Mamba
Hello,
I am trying to restore a Iwill xa100 plus, we’ll not me, but a friend much more expert than me in soldering and electronics.
We are having a hard time on identifying a component that needs to be changed.
It is identical to the attached one.
He says it is an oscillator but cannot identify the frequency.
Any idea where to find it?
Alternatives?
Thanks
Reply 1 of 16, by BitWrangler
That one I think is near your RTC and might be the wall time clock clock crystal, usually 32.xxx khz.... you can actually steal one out of a quartz wall clock. Symptoms of it going out of spec would be system time going all over the place. RTC fail on boot etc.
Reply 2 of 16, by Mamba
BitWrangler wrote on 2023-03-06, 04:25:
Thanks,
Actually I have two.
The one posted (in good shape) is near the bios chip as you said.
But the one probably faulty is near the south bridge.
Attached, circled in red.
Reply 3 of 16, by TrashPanda
Mamba wrote on 2023-03-06, 04:57:
Thanks, Actually I have two. The one posted (in good shape) is near the bios chip as you said. But the one probably faulty is ne […]
Thanks,
Clock oscillator for the ISA bus since its sitting right next to it?
Reply 4 of 16, by BitWrangler
Okay that's the 14.xxx Mhz reference crystal then. The one ringing to rule them all, 48mhz for the USB lords, 24Mhz for the floppy kings etc.
Reply 5 of 16, by Mamba
BitWrangler wrote on 2023-03-06, 05:05:
Thank you so much, so (sorry I am stupid) I have to search for…
Oscillator at 14.xxx MHz?
Reply 6 of 16, by BitWrangler
xxx because I don't remember trailing figures it's 14.31818... cut off at 14.318 Mhz often. But you should see if it looks like saying something like 14.3 on it somewhere when you desolder it.
Reply 7 of 16, by Mamba
BitWrangler wrote on 2023-03-06, 05:16:
Unsolded, it is destroyed and unmeasurable. It is written s893. Does not say mutch.
Someone else said it should have a value of 32.768khz, not 14.318Mhz…..
The worst part is the difference from kHz to mhz, plus I am not able to find oscillators of the same shape that have 14.xx mhz value, always 32.768khz…
Is it possible that it is exactly the same in value also other than shape?
They even share the same S893 sign on it.
Reply 8 of 16, by vstrakh
Mamba wrote on 2023-03-07, 05:24:
Totally ok when PLL is involved.
But in this case look into ALI M1543C datasheet, it needs 32.768kHz quartz to handle the DRAM refresh in STANDBY/SLEEP/SUSPEND modes.
Reply 9 of 16, by pentiumspeed
The clock generator next to this have 14.318MHz crystal. The ALi southbridge always have 32kHz crystal for the time of day clock. Use 32kHz on this one.
Cheers,
Great Northern aka Canada.
Reply 10 of 16, by PD2JK
Does your friend or an acquaintance happen to have an oscilloscope? Odds are the crystal is fine.
Reply 11 of 16, by Mamba
PD2JK wrote on 2023-03-07, 18:43:
It is totally destroyed/burned
Reply 12 of 16, by PD2JK
Ah! I missed that part, no use in measuring a scorched component of course. 😀
Reply 13 of 16, by BitWrangler
Checked my ALI board, the RTC and FSB crystals had nothing visible on outward face, the one by the southbridge did say KSC9B which seems hard to look up but some suppliers pages were offering me other 32khz crystals from that search.
Reply 14 of 16, by smtkr
Just curious, why are these oscillators always folded down onto a metal pad (and sometimes secured like pictured above)?
Reply 15 of 16, by pentiumspeed
to protect them from breaking off if they were standing up. Common sense.
Cheers,
Reply 16 of 16, by BitWrangler
The leads are a bit thin and whiskery compared to electrolytic caps you might notice.
Also there might be some spurious emission and stability benefits to the belt and braces ground plane strap.
