First post, by Kekkula
So I have this board.
https://theretroweb.com/motherboards/s/hyundai-super-16t
Board posts but since I don't have 5 1/4 360kb drive, witch I assume it tries to boot from, I'm stuck.
1.12 MiB
Boot screen
Does anyone know if there is a modified bios for this board that boots from 1.44mb 3.5" floppy drive? Or tools to modify original bios?
Reply 1 of 5, by konc
On a very similar model with the same BIOS you don't need to configure anything. Just connect a HD 3.5" drive and obviously use a bootable DD disk (or a HD with the hole covered).
If you got the original case/cables you might need a new cable as depending on the original configuration it's possible that the cable only has a 5.25" connector at the end intended for drive A:
Reply 3 of 5, by Kekkula
Aaaaarrrrghhh!
Been struggling with this whole day... Downloading different dos images writing them from Linux and from virtual Windows tried about everything....
Then it occurred to me that maybe it's just perfectly working Sony 1.44mb drive that just doesn't read 720k formated disks. Took old panasonic drive witch I've been using with amiga and the computer booted first try...
Aaaaarrrrghhh!
Reply 4 of 5, by Horun
Good job. Yes there are some 1.44mb floppy drives that have issues reading 720k disks.
