First post, by RegTheEvil
- Newbie
I have Aureal Vortex Advantage AU8810A1 PCI sound card. I am using sound card only under DOS at the moment. I noticed that sounds are quieter than from my other sound cards (YMF724 or SB Live).
My AU10DOS.INI file contents look like this:
[AU10DOS.COM]
MPU401External=0
ModemBase=0x000
ModemIRQ=0x0
JoystickBase=0x000
MPU401Base=0x330
SBFMBase=0x220
FMBase=0x388
SBFMDMA=0x1
SBFMDMA2=0xFF
SBFMIRQ=0x5
PCIIRQ=0xA
CPUSpeed=0x216
Reserved2=0x00
Reserved1=0x00
mixer_master=0x00
mixer_phone=0x00
mixer_mic=0x00
mixer_line=0x00
mixer_cd=0x00
mixer_aux=0x00
Reserved4=0x00
Reserved3=0x00
Reserved2=0x00
Reserved1=0x00
string_prod=Vortex PCI Multifunction Platform
string_ven1=Aureal Semiconductor
string_ven2=(c)1997 Aureal Semiconductor, Inc. Fremont, CA
string_err1=Error: Run Windows 95 to set configuration
string_err2=Error: Could not find a PCI BIOS
string_err3=Error: Could not locate Vortex device
string_err4=Error: Could not enable Vortex system
string_err5=Error: An unexpected error has occurred
string_msg1=Sound Blaster support is enabled at port
string_msg2=Sound Blaster support is disabled
string_msg3=Joystick enabled at port
string_msg4=Joystick support is disabled
string_msg5=MPU401 MIDI system enabled at port
string_msg6=MPU401 MIDI system is disabled
string_msg7=Modem enabled at port
string_msg8=Modem is disabled
I tried changing numbers from master volume to something other than 0x00 but heard no difference.
Is there any MS-DOS mixer utility for this model to change volume settings or is the card just quieter? I had to attenuate this card 9 dB to match the sound output level of my other cards in this machine. So far haven't noticed any quality loss but I haven't tested with headphones yet.
I saw a mixer utility for AU8830 card and some other utility for both Vortex 1 and 2 cards but not for Advantage which I have.
Any mixer utility to change volumes for AU8810?
