Reply 21 of 28, by chris2021
My question was how were modern cases painted, to achieve that slightly gritty, semi-gloss finish , probably more to the matte side, and that was the reply I got. I thought maybe just maybe the person knew what they were talking about.
The powder coated stuff I've seen, mostly auto rims and such, had a similar finish to modern computer casres. I have 5 or 6 that were made in the last 5 years and they all have a similar finsih. I guess you can vary a powder coat finsih like regular paint. Yeah, dopey to assume that they all could have been powder coated. Unless the Chinese have developed a cost effective method. Doubt it. Perhaps it's a variant of the sloppy nozzle method, yet to be attempted 😀. It just spits more finely ... ? Or maybe there is a fine grit (or toiletries) mixed into the paint. What do I know.
Anyhoo I need approximate 6 more hours in a day to play w/all my crappola. And that's not coming off my sleepy time. Sleep is like a narcotic to me.
Reply 22 of 28, by informatyk
I sprayed one of my case. It was very yellow, pic don't show how bad it was. It did make case brilliant white again, but the surface is not nice when touching and in close it seems like it's too much ink in some places. It's hard to make it right. I wouldn't recommend doing this.
    250.97 KiB
    586.97 KiB
Reply 23 of 28, by Shponglefan
informatyk wrote on 2023-08-22, 15:37:
What kind of paint did you use? How many layers?
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 24 of 28, by Grem Five
BitWrangler wrote on 2021-09-30, 15:06:
Chris had it right I think, they just twiddle the nozzle on the spray gun so it shoots bigger blobs, or turn the pressure down so it doesn't atomise it right.
This is how we use to do it when we sprayed prototype cases/servers we made for IBM. We had to make the finishes match very close to what it looked like on production products or they would get rejected and we would need to try again.
Reply 25 of 28, by justin1985
In my other hobby of model railways people use a spray paint product called Plastikote Suede to give texture for modelling stone or especially concrete surfaces (like bridges and roads).
It seems like availability comes and goes - it is out of stock at Amazon UK now, but there are some sellers on Google shopping search. It used to be sold in B&Q, and I think they actually had a similar Rust-Oleum product last time I looked.
There's a long discussion of it here: https://www.rmweb.co.uk/topic/119853-plastiko … -suede-returns/
Modellers tend to use it for texture then add additional colours to weather it in, but actually the colour from the can is quite beige like!
Reply 26 of 28, by Socket3
ildonaldo wrote on 2021-09-14, 12:55:
Hi, I've got a beautiful, but old case thats hood I probably have to grind down to the bare metal because of some deep scratches […]
I've got a beautiful, but old case thats hood I probably have to grind down to the bare metal because of some deep scratches and corrosion.
How can I recreate or mimic the original surface structure (e.g. with a paint roller)?
TNX & regards
I've had great results applying a basecoat of liquid filler (essentially really thick primer) using an undercarriage paint gun:
35.54 KiB
Then spray painting the case as normal.
Reply 27 of 28, by informatyk
Shponglefan wrote on 2023-08-22, 15:50:
One layer. In some places second layer. The color is great but still too white, it's looks like from factory. I'm not used to it.
    248.97 KiB
Reply 28 of 28, by ildonaldo
informatyk wrote on 2023-08-24, 11:22:
some time ago I made a visiual comparison of the two colours that I use for spraypainting old cases ...
colour comparison RAL 1013 VS RAL 9002
Building my own PCs since 1991 - for my retro builds it's "no CF-disks, no Floppy emulators, no modern cases etc.", only the real and authentic stuff whenever possible.
