First post, by megs8888
Anyone have any info on how to run Space quest 6 under XP, Also Spycraft by Activision and Myst masterpiece edition, if I can get these games working I will be so happy thankyou all 😀
do I have to install the game to the folder where dosbox is stored or do I have to do something with dosbox im not very good with the technical stuff if you could explain that would be great. thanks 😀
_________________
I always thought Space Quest worked on XP flawlessly 😖
Maybe it was before SP2
wrote:I always thought Space Quest worked on XP flawlessly
...except for the speed bugs and not at all if you have 64 bit Windows. DOSBox is the only way to go.
