First post, by gazmercer
Hi all,
Never used a forum like this before, hope I am posting in the right section.
I have a few old programs that I am using for legacy products that are no longer supported by the manufacturers. These are a Z80 compiler, an eprom programmer and a PCB board layout program.
I have got two of the programs running fine with the dosbox, but I cannot get the PCB layout program to run.
The problem is that the PCB program is dongle protected on the parallel port. I have followed all the patches that have been done by HAL9000 and searched all over the forum, but I cannot come up with the reason why this particular program will not work.
My eprom programmer is able to access the parallel port and program/read from eproms so I think I must have done some things right.
I am ready to give this up as a bad job if no one can help.
