First post, by NHVintage
Hi - I feel like this should be somewhere here, but I've been searching and can't find it so I apologize if I missed it elsewhere.
I have the Epson Equity 1+. It appears on review that it will only support 720k drives, not 1.4Mb - and unfortunately the Gotek floppy emulators I have are the 1.4Mb variety. Is it possible to flash some sort of firmware onto the Gotek to change it to a 720k version? Does it actually matter? Is there some other way for these drives to support 720k? Or are there hardware differences? Thanks!
Reply 1 of 5, by GigAHerZ
I'm using FlashFloppy firmware on my standard 1.44 goteks. At least with FlashFloppy, it's purely software that controls what drive it looks like.
Reply 2 of 5, by eesz34
NHVintage wrote on 2023-09-01, 18:00:
I've even loaded 1.2M images on a Gotek and set the BIOS to 5.25" 1.2M drive, and it worked fine.
Reply 3 of 5, by NHVintage
yeah I wish I could get into the BIOS. this old machine requires a program on the floppy and I can't get a floppy working and thus can't run it or the diagnostics that are also on a floppy. 😁
Reply 4 of 5, by wiibur
If the stock firmware is not working for you then maybe the HxC firmware will work (it costs 10€ though).
Edit: Before you do that, did you try formatting your USB with the 720K option from the Batch Manage Tool? That's what I use on stock goteks to format and it has several format options.
Reply 5 of 5, by NHVintage
I wound up getting a flashfloppy-preinstalled drive on ebay and it works like a charm (and it's a lot easier just copying img files right onto the usb stick with a modern pc, without any tables or other stuff).
