First post, by Hamby
I have a MIDI keyboard with usb-b connection, and no midi connection.
I would like to use it with my vintage computers, such as my 486 running DOS, or my Amiga or Mac SE/30, but they obviously lack USB.
But there are midi adapters for all of them (like the game/midi port on the 486's sound card, to which I've attached a midi adapter).
Is there any (fairly simple) way to connect the USB-B of the keyboard to the MIDI-IN of my midi adapter?
I'd like to use the keyboard for input, and my MT-32 for output.
Reply 1 of 4, by darry
Hamby wrote on 2023-11-18, 19:22:
I have a MIDI keyboard with usb-b connection, and no midi connection. […]
Something like this should do it :
# for USB 1.1 MIDI devices :
https://www.amazon.com/CAMOLA-MIDI-Host-Inter … r/dp/B08MZY59B7
# for USB 2.0 "high speed" MIDI devices ( seems backward compatible with USB 1.1 MIDI devices) :
https://www.amazon.com/CAMOLA-Speed-Converter … 1/dp/B09S5YC2Z9
Just an example, not an recommendation or endorsement .
EDIT : If you just want to use the keyboard as controller, see also this https://www.serdashop.com/USBMIDIHost
Reply 2 of 4, by jmarsh
darry wrote on 2023-11-18, 19:52:
I think that's exactly what OP needs... but that price is rather excessive. You can see from the screenshots that it's only a PIC MCU that sells for less than $10, so you could save quite a bit by making your own from practically any MCU with a programmable USB Host port.
Reply 3 of 4, by Pierre32
jmarsh wrote on 2023-11-18, 20:42:
If you already have the skills, tooling, time, consumables, and reasonable availability of parts.
Reply 4 of 4, by darry
Another option is to use an intermediate Windows or Linux computeras a makeshift MIDI bridge using Virtual MIDI cable or Jackd .
