First post, by 7F20
- Member
Is this possible?
I am doing this: mount d d:\ -t cdrom
and the CD I insert is detected only if it's in the drive before I start DOSBox. After I start DOSBox, the filesystem doesn't seem to recognize any new CDROMs I put in the drive. I have a feeling this is expected behavior and that I'm missing some kind of simple solution, though I've gone through the manual and nothing is jumping out at me. I also tried adding the -usecd 0 switch with no difference
thanks
