First post, by dbarton
- Member
does dosbox support MIDI IN yet?
or still just out?
or still just out?
still just out.
not really needed for games that IN
Water flows down the stream
ok, was hoping to use for a music sequencer, but seems to work quite well for playback!
never gonna get added?
As Qbix said: It is not needed for game-play, and game-play is the focus for DOSBox. If you want full emulation, try virtualisation with QEMU, VPC, WMware, ...
_________________
Working on it for win32. It's functional except the intelligent mode which still hangs some old sequencers...Now the work is a stalled because I'm not at home until April (and then for a week only).
I'd be happy to help with any beta testing you do for MIDI input. I use Sequencer Plus, and as far as I know it does NOT use intelligent MPU mode..
Any chance of trying it as you have so far?
Well, I'll try to get a build system (mingw probably) running during the weekend, so I can produce a build, then I'll probably upload (and/or at least patches to sf.net) it so you can begin beta testing...
ok, please keep me posted if oyu do..
I uploaded a patch to sf.net:
http://sourceforge.net/tracker/index.php?func … 551&atid=467234
Here's a mingw binary that I compiled yesterday (use sdl dlls from dosbox installation). You can add "inconfig" parameter in dosbox.conf below the "config". It's used in the same way (0,1, etc or just empty, or "none" to disable).
To test without real midi input device, you can use something like a "MIDI yoke" and a program that outputs midi to it's virtual device (but not digital sound as it might mute dosbox window). For example I used another instance of dosbox with disabled sound to output MIDI and a small app called "byear".
If it works we can open a thread in Patches section. I didn't test it outside of machine at home, although I have a laptop here on which I could set this up. But here at CERN I'm pretty busy, anyway 😵
Is there any further work done on implementing MIDI IN?
I have downloaded the version by Srecko in this thread and it sorta works, sometimes.
The problems I have are -
Does not recognise more than two notes played simultaneously or fastly played musical phrases.
Does not always record 'NOTE OFF' messages.
Sometimes does not start to recognise my MIDI keyboard unless I first play some notes from within the sequencer I am running in DOSBOX.
I am attempting to run 'Voyetra Sequencer Plus' from DOSBOX.
Would appreciate words from others using this sequencer in DOSBOX and hearing their experiences.
I also use SPG.
I have not used the MIDI *in* patch as I'm using a different patch to improve timing output.
For *playback* with SPG, it's working very well.
I know gaming is the primary goal of DOSBox, but allowing people to use old Dos applications are priceless. You won't find any working emulator that has the same device support as DOSBox, and modern sound hardware aren't neccesary 100% backwards compatible with the old hardware. I would also love to see full support for MIDI input in DOSBox.
Sadly, messages here relating to MIDI input only seem to get posted every few months, and as best I can tell, none of thr developers seem very interested in this part..
MIDI *output* is working very well with the TESTMT32 patch I have posted about in the older Dosbox version, but that hasn't been added to the new version yet.
well it's free 😉
The priceless people with unreplace hardware should do their best convince me of it.
Srecko has improved his patch a bit a few weeks ago.
Posting stuff like that decreases the interest even more.
I don't follow. Wasn't I just stating the truth?
I'm not saying the developer should be intersted - just pointing that it's prety clear the direction is for games.
Erm no? How do you come to the conclusion that nobody is interested?
I'm not aware we posted something like that anywhere.
The first thing stated in the "wishlist" message:
"The absolute #1 priority is Game Compatibility. Not Wordstar/Wordperfect or some custom app that you need to print or connect to your host via serial. All suggestions should keep in mind the goal for increasing DosBox GAME compatibility. "
Have I misunderstood, and there is a real interest in adding working MIDI and in and out? That would be great!
Personally i don't have any use for it, but it seems to come along nicely.
And "interest" and "integrating it into official dosbox sources" are quite
different things, for the latter part see Qbix's posting.
Actually, the best thing about an added Dosbox MIDI-IN capability would be for adding Gravis Ultrasound support to all games which only support General MIDI or had problems with Ultrasound DOS drivers. The idea being to have two instances of DosBox running, the first to execute the game in question - with MIDI-Out stream sent to the host OS, the second instance of Dosbox to just run the accept the host OS MIDI stream via the (hopefully added) MIDI-IN capability with the Gravis ULTRAMID program executing.
This would not only spin off the Ultrasound emulation/MIDI rendering to another thread (in another process) but would also make the Dosbox Gravis Ultrasound MIDI rendering available as another Windows software MIDI device with the use of Win32 MIDI 'virtual cables', just as do the Roland VSC, the Yamaha XG WDM softsynths or the built-in Microsoft GS wavetable softsynth. This capability would also add Gravis Ultrasound support to the Windows NTVDM, actually working as opposed to the Win32 based Gus32EMU GUS emulator which never really worked...
We'll just have to wait and see...
dvwjr
