First post, by Yoghoo
Got a Trust Sound Expert Wave 32 sound card which looks like to be the same as an Aztech Sound Galaxy Waverider 32+ according to the specs in this post Re: Help to Identify Aztech ISA Sound Card.
It is recognized as an Aztech Sound Galaxy Washington 16 in Windows 95 though. But whatever driver I use it always is using 2 IRQ's. One for SB (=5) and another one for something else (7 or 11 depending what is free). That is excluding IRQ 2/9 which is used by the MPU-401 on the card.
The second IRQ is a mystery for me. Where does it come from and by what it's used? It can only be set to IRQ 7 or higher in Windows 95. In the DOS config tool I can only see one IRQ which can be set (besides the MPU-401). Anyone knows?
Reply 2 of 10, by Yoghoo
DerBaum wrote on 2024-01-25, 03:11:
Can you post a picture of the card?
When i search for it on google it looks like a OPTI card not Aztech.
Maybe its the IRQ for the IDE connector?
See attachments for pictures. I disabled IDE in the config utility already. Also I disabled Windows Sound System just to look if that made a difference. But 2 IRQ's are still used.
    149.09 KiB
    315.47 KiB
Reply 3 of 10, by Joseph_Joestar
Yoghoo wrote on 2024-01-24, 23:05:
Windows Sound System (WSS) maybe?
Some sound cards allow IRQ sharing between SB and WSS, but others need separate resources for each.
Reply 5 of 10, by Yoghoo
Joseph_Joestar wrote on 2024-01-25, 08:45:
I disabled that already before but it still uses an IRQ.
Reply 6 of 10, by Yoghoo
giantclam wrote on 2024-01-25, 09:06:
IDE CD interrupt... if you can get the right version of the hwset utility it shows... […]
I played around with it. But even if I set /CDIRQ:N and /CD:D and write to EEPROM (I changed the jumper to use EEPROM in the mean time as well) it still uses 2 IRQ's.
Reply 7 of 10, by Yoghoo
I got a copy of the original floppies for this card. But can't use them as they are probably for Windows 3.1. Installing them makes Windows 95 not starting up again.
But if I look in the SETUP.INF on those floppies I see a line "Wave IRQ=7, 9, 10, 11" in it. So it seems the Wave chip needs a separate IRQ (besides the SB and MPU-401 IRQ).
Makes sense I guess but it's a bit inconvenient as I am out of IRQ's. So probably need to disable the parallel port which I tried to avoid. 🙁
Reply 8 of 10, by DerBaum
Yoghoo wrote on 2024-01-25, 09:32:
I have problems too writing the settings to the EEPROM on GEN3 Aztech cards. For example on my MMSN824 (wich should be exactly your card but without the wavetable).
It just doesnt write the settings.
The star in HWSET shows the base settings not the actual settings.
Reboot the system without loading config.sys and autoexec.bat. Then run HWSET with a wrong command (for example HWSET /d). This will not change the settings (and tell you have used a wrong command) but show the summary with the settings from the card eeprom. (On my card it always sets itself to 0x240 and irq 7 with some weird DMA settings).
I am sure i do something wrong, and i have not figured out what...
I was so desperate that i even read the EEPROM with my EEPROM reader and its empty. (Just the first byte is 01 all others are 00).
And i am also not quite sure if the AZT2316A(your card) acts the same as a ATZ2316-S(MMSN824).
Generation 3 can have 4 different chips. AZT2316 (example MMSN819), ATZ2316-S (example MMSN824), AZT2316A (example MMSN826), AZT2316R (example MMSN845).
I am not sure if each chip needs a specific HWset version.
FCKGW-RHQQ2
Reply 9 of 10, by Yoghoo
DerBaum wrote on 2024-01-25, 12:38:
I have problems too writing the settings to the EEPROM on GEN3 Aztech cards. For example on my MMSN824 (wich should be exactly y […]
Generation 3 can have 4 different chips. AZT2316 (example MMSN819), ATZ2316-S (example MMSN824), AZT2316A (example MMSN8826), AZT2316R (example MMSN845).
There should be a jumper on this card as well then. Mine got a jumper to use the EEPROM or not. Maybe try to add or remove a jumper for that option.
Reply 10 of 10, by DerBaum
Yoghoo wrote on 2024-01-25, 12:52:
The JMPCFG position on my card doesnt change anything. I have tried both positions.
First i used it wrong because i thought 1-2 is on the left position... But its actually on the right position to enable the eeprom (on MMSN824).
FCKGW-RHQQ2
