Problem with Pentium Pro build
Reply 21 of 24, by boggsman
I'm just gonna switch to a Quadro4 NVS 200. Should be a much better card.
Reply 22 of 24, by Sphere478
boggsman wrote on 2024-02-06, 12:37:
Try a Quadro 2 with 7.76 drivers. Edit: needs a pci-agp adapter unless you can find a pci version
Try radeon 7500-9200-9250
Sphere's PCB projects.
Reply 23 of 24, by boggsman
Sphere478 wrote on 2024-02-06, 15:16:
What's wrong with the Quadro4? Reason I got it is because it's available and affordable. It's a DX7 card. Those cards are hard to find in PCI form. I want it to fit in the case, I don't think that will work with an adapter right?
