First post, by urbantaz
🤐 ok i know this forum is for games. I however have an application problem. I have tried dosbox and it works up until a point for me. I need to print to a usb printer which can be solved by using dos2usb my problem is when i network the app which is supposed to work in pure dos it crashes on every user after the first. Is there any settings i can use to make this work. I work for about a week and then nothing. I need help this is for a customer and they as well as i am are getting frustrated. The company that produced the app was supposed to make a windows version but they abandoned that project so now we are stuck with this until we can find a decent app to replace it. So all this to explain i am in a hole and in need of help. The error i get when others try to login is a type mismatch. Please help
Reply 1 of 4, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
There is the virtual printer patch too. It produces a picture which you can then print.
1+1=10
Reply 2 of 4, by eL_PuSHeR
[Moved]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 4, by eL_PuSHeR
By the way, did you know you can print to an usb printer as if it was just a common old ms-dos printers? At least, you can if you're using WinXP (don't know about Vista).
Try something like this:
+ Enable printer sharing. Name the shared printer.
+ Open a ms-dos window (cmd.exe) and type in:
net use lpt1: \\your-network-name\shared-printer-name /persistent:yes
That will allow you printing to lpt1 and redirecting the flow of data to your real printer.
You could use this in conjunction with modified parallel access DOSBox H-a-l-9000 mentioned.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 4 of 4, by urbantaz
yes i know that. the problem with using winxp dos is that the app doesn't share without crashing. dosbox i can at least share. i am trying the virtual printer one now
