First post, by matti157
I setup the game for mt-32 sound output.
I use a Roland SC-88 configured in MT-32 emulation, the sound works fine!
But I have no effects, no engine sound, no crash sound....
If I configure the game for Sound Blaster all audio is ok (music and effects)
Any ideas?
My config:
-DOS 6.22
-AWE64
-Roland SC-88
Reply 1 of 9, by badmojo
You can't have both sound blaster FX and MT-32 at the same time in some of these older games, it'll try and do the FX via MT-32, which obviously doesn't sound too flash. Not even the music sounds good via MT-32 for these '4D' games IMO, I just stick to sound blaster.
Reply 2 of 9, by wbahnassi
Stunts doesn't use digitized sound at all. Only Adlib for both music and FX. When running on MT-32, you should indeed hear everything sounding via the MT-32, including engine and skid and crash sounds.
The only thing I don't remember is whether Stunts programs the MT-32 at start up, or just use the stock instruments as-is. If it's the latter, don't expect the SC-88 to be able to handle it. There are other games that work with the base MT-32 instrument list (e.g. Monkey Island), and that will work fine on SC-88 as well.
Reply 3 of 9, by badmojo
wbahnassi wrote on 2024-03-05, 11:00:
I didn't realise that but you're right - Adlib and Sound Blaster are listed separately in the sound setup but they both sound exactly the same 😀
Reply 4 of 9, by matti157
Would I basically hear the audio effects if I had a real mt-32? 😁
Reply 5 of 9, by wbahnassi
Yes 🙂
Reply 6 of 9, by leileilol
MT-32 mapped midi playing piano notes for sounds is fun in its own way too, especially for that nascar game dsi did 😀
Reply 7 of 9, by mkarcher
At least for the sound effects, Stunts does define custom sounds on the MT32 during start-up usinig SysEx messages, so any solutiion trying to map MT32 patch numbers to GM/GS patch number and then playing back those GM/GS patches will not work with Stunts.
Reply 8 of 9, by Azarien
mkarcher wrote on 2024-03-06, 06:33:
If I remember correctly, music plays fine but sound effects are replaced with nonsensical piano notes and such.
Reply 9 of 9, by matti157
Azarien wrote on 2024-03-06, 07:40:
Exactly, but in a very soft way
