Reply 20 of 24, by asdf53
bten wrote on 2024-03-14, 18:28:
Thank you for testing for me, I appreciate it.
Gonna return and get an FX card from a known manufacturer.
I also found this:
https://forums.guru3d.com/threads/geforce-2-m … -64mb-400.2964/
I bought Apollo Gf2 Mx 64m and had 1200 on 3dMark2001. Took off heatsink and found Mx200 on chip. ;(
Should be another piece of evidence in case the seller doesn't believe you.
Reply 21 of 24, by bten
asdf53 wrote on 2024-03-14, 20:13:
I also found this: […]
I also found this:
Thank you. Again I appreciate the help.
Learned my lesson buying no-name gpus. Better it happened on a cheap one than if I bought something pricey.
Staying away from this "Apollo" brand 🤣.
Reply 22 of 24, by sydres
As the original poster in the weird geforce2 post, I'd like to know if your card came in this box?
The attachment IMG_20240406_132209564.jpg is no longer available
Under hwinfo
Core=200mhz
Ram=125mhz
3dmark99-2603
3dmark2000-2122
It might not be fast but seems fairly stable, and image quality is better than the tnt2 m64 I had in the system
Reply 23 of 24, by bten
sydres wrote on 2024-04-06, 17:35:
As the original poster in the weird geforce2 post, I'd like to know if your card came in this box? IMG_20240406_132209564.jpg Un […]
Under hwinfo
Core=200mhz
Ram=125mhz
3dmark99-2603
3dmark2000-2122
Yes, identical box with identically odd peeling adhesive material.
Reply 24 of 24, by sydres
Interesting I need to pull mine back out and check the GPU. I'm pretty sure when I pulled off the heat sink mine said mx 400!
