First post, by dekkit
HI all,
I've found a few boxes of old IBM PC 5.25inch and 3.5inch disks with a lot of software that may or may not be worth extracting and uploading somewhere (i.e. typing tutors, graphic viewers, early word processors etc)
Usually this sort of thing comes in handy once in a while when you're looking for something to open a file.
While most of the games are already available online, I'm not sure about some of the other stuff which is why I'm wondering if it's worth extracting or is it just wasting time and effort?
Then the question of where to upload it to help preserve it and so it's discoverable (archive.org seems the most obvious spot if not here)
Looking for advice or if there is another thread that discusses this (or some other active archival project that is collecting utils etc) then please point me in the right direction.
Thanks all,
Dek
Reply 1 of 12, by StriderTR
Create a free https://archive.org/ account and archive your finds there. That's what a majority of people do. It's an excellent resource for hard to find data.
I just started mine as well, only has a few things on it at the moment, until I have time to start going through all my disks. 😀
REMOVED
EDIT: Here's a much better example of one of the best floppy disk archives REMOVED
Retro Blog: https://theclassicgeek.blogspot.com/
Archive: https://archive.org/details/@theclassicgeek/
3D Things: https://www.thingiverse.com/classicgeek/collections
Reply 2 of 12, by dekkit
Ta, will get to work. Its interesting going back seeing all this stuff and using dosbox to quickly see what's on them.
We take so much for granted now days.
Reply 3 of 12, by matti157
Make an image of the floppies with winimage and upload the image to internet archive! You would be doing a welcome thing to many people
Reply 4 of 12, by gerry
dekkit wrote on 2024-03-26, 13:23:
nice to do that, hopefully will come in useful for some
true about taking things for granted , one of the things i realised what archive org itself - what would happen if they stopped!? we sure use them a lot
Reply 5 of 12, by ldeveraux
StriderTR wrote on 2024-03-26, 05:47:
Create a free https://archive.org/ account and archive your finds there. That's what a majority of people do. It's an excellent […]
REMOVED
What was removed here and why?
Reply 6 of 12, by konc
ldeveraux wrote on 2024-03-26, 17:05:
REMOVED
A link to a specific archive.org page with software to download.
Reply 7 of 12, by StriderTR
konc wrote on 2024-03-26, 17:13:
REMOVED
Yep, that's what I get for posting and not thinking in the middle of the night when I should be sleeping. 😜
Reply 8 of 12, by Tripredacus
Along these lines, what programs are recommended for making the disk images?
Reply 9 of 12, by dekkit
Tripredacus wrote on 2024-03-26, 19:25:
I used specific hardware PCB 'greezeweazle' PCB (v4.1) which has a bunch of scripts and front end to extract .img files using flux transitions (it avoids the PC floppy controller and connects via USB(
Then 7zip to poke around the img files and see what's in there.
If using a standard PC with a floppy drive I'm sure there are dos utils out there (I think freedos has some, and probably a heap available on various windows).
If there some weird copy protection, I'll probably create multiple formats (.img,zip,raw) otherwise just simple .zip files to make it easy use with emulators.
Reply 10 of 12, by Matchstick
dekkit wrote on 2024-03-26, 04:19:
Thanks all,
Dek
I suggest you join Digitoxin's PC Game Preservation Discord
Reason: Warez discord link
