Ripthron wrote on 2024-04-10, 04:00:
BitWrangler wrote on 2024-04-10, 03:35:
That looks vaguely like an M571, is the onboard disabled, or did you even reset CMOS for it to detect new config?
Yes, It's an M571. Do I need to disable onboard video and clear the CMOS?
Clear the CMOS first and test, then Disable onboard and test, that card should work just fine, just checked and that card is PCI 3.3v only ...does your board support both 3.3v cards and 5v cards or only 5v PCI cards ?
Hmm that board is only PCI 1.0 compliant which means 5v cards only .. Im guessing it doesn't like 3.3v only video cards which that RageIIc is, it wasn't till PCI 2.0 that 3.3v was supported.
Try and find a PCI card with the notch at the read of the PCI connector as that will be 5v compliant, notch at the front is 3.3v only and two notches means compatible with both 3.3v and 5v
