First post, by psaez
Hi.
I mean this:
I got it hanging on the pc case.
Hi.
I mean this:
There are brackets for pci slots than can be 3D printed you can find them online no problem
mmx_91 wrote on 2024-04-10, 20:45:There are brackets for pci slots than can be 3D printed you can find them online no problem
Or front panel brackets too-- https://www.thingiverse.com/thing:4368606
And can't be purchased already printed?
Mounting in a drive bay would be one option.
Another option would be to use a straight angle IDC 40-pin female to female adapter to plug the adapter directly into the IDE port, like a makeshift IDE DOM.
psaez wrote on 2024-04-10, 21:18:And can't be purchased already printed?
Sure. There are a lot of options on ebay for $10-$15
I would guess that out of 3 or 4 modems with a double line jack, you can find a bracket that will mount it to a spare slot hole and leave the SD card externally accessible.
BitWrangler wrote on 2024-04-11, 02:38:I would guess that out of 3 or 4 modems with a double line jack, you can find a bracket that will mount it to a spare slot hole and leave the SD card externally accessible.
True. Modems have became a consumable resource that when activated, produce a ISA/PCI slot cover.
douglar wrote on 2024-04-11, 02:01:psaez wrote on 2024-04-10, 21:18:And can't be purchased already printed?
please can you show me some links?
can you show some examples? can't understand what are you refeering to
psaez wrote on 2024-04-11, 12:46:douglar wrote on 2024-04-11, 02:01:Sure. There are a lot of options on ebay for $10-$15
Search Ebay for "sd ide bay". Make sure you don't mistakenly order a 1/3 height, because while cheaper, few computers use that size.
My local public library provides some high quality 3d printers that the public can use. They print stuff for me at $1 per 30 grams of filament, and I think the quality is higher than most of the guys selling on ebay.
douglar wrote on 2024-04-11, 12:53:psaez wrote on 2024-04-11, 12:46:douglar wrote on 2024-04-11, 02:01:Sure. There are a lot of options on ebay for $10-$15
that's amazing, but don't know anything like that con my city, in Spain.
psaez wrote on 2024-04-11, 12:46:BitWrangler wrote on 2024-04-11, 02:38:I would guess that out of 3 or 4 modems with a double line jack, you can find a bracket that will mount it to a spare slot hole and leave the SD card externally accessible.
Just a regular old 56k or slower PCI or ISA modem like this..
And the hole where the phone ports are will probably be big enough for SD card... check a few to find one with mounting holes in right position, or mount it to only one and ziptie strap it to the other, or add a metal strap or something.
