First post, by L.PE
Hello,
I use DOSBOX to compil with an old compiler IC86
Sometimes, with exactly the same code to compil I got DOSBOX crash.
I have catch the return code with %errorlevel% variable after the call of DOSBOX and the return code is -1073741819.
Does this error speak to somebody?
Have you some ideas to dig the issue please?
Here the data from windows event:
Faulting application name: DOSBox.exe, version: 0.74.3.0, time stamp: 0x5d136ad9
Faulting module name: DOSBox.exe, version: 0.74.3.0, time stamp: 0x5d136ad9
Exception code: 0xc0000005
Fault offset: 0x000bc084
Faulting process id: 0x1ca4
Faulting application start time: 0x01da8f1293451646
Faulting application path: D:\App\DOSBox-0.74-3\DOSBox.exe
Faulting module path: D:\App\DOSBox-0.74-3\DOSBox.exe
Report Id: cdc73181-650d-436f-8ff1-8f297105ec38
Faulting package full name:
Faulting package-relative application ID:
Regards
