vico wrote on 2024-04-24, 23:40:
Kordanor wrote on 2024-04-24, 15:51:
Are you using the normal version of fatal racing or an inofficial 3dfx patch? If you are using the latter, you can post a link on where to download the patch and I can test it (if it is compatible with the 2 german versions I got)
I understand that these unofficial patches are designed for Voodoo 1 and Voodoo2. Anyway, I tried them and the screen goes black and nothing else happens.
If you can, try it with your German version 2.0 and let me know if it works correctly for you.
With my V3 3500 on the German version I get a black screen for 3s or so, then I am back to dos.
But now I don't understand: Are the screenshots you sent before also from the 3dfx version or are these from the regular?
If you use the high resolution version with SVGA, then I have something similar. But that is because the game uses 720x400, and that 720x400 is fully used in its height (400 pixels) while the width seems to have the probably 80 black pixels to the right, which you would then need to crop off. Youl will likely see the same on Sid Meiers Transport Tycoon 1. Just that this game has borders left and right you need to crop off. Also both games need a vertical adjustment (they are too far down).
