Wolf3d left shift
First post, by theelf
Hi! someone knows if there is a custom build for DOS of wolf3d that fix the left shift run problem? thanks
Disable num lock fix only the always run, but still the shift key interfere with cursor keys
Reply 1 of 11, by badmojo
I use this amazing project: wolfmidi+wolfdosmpu - Wolf3D/SoD music in General MIDI (fully-automatic converter) + WOLF3D.EXE with MPU-401 support
You don't need to use the MIDI stuff, although that's awesome too. WASD and mouse support is great and solves the left shift thing too.
Reply 2 of 11, by theelf
badmojo wrote on 2024-04-17, 04:29:
Thanks for answer, in fact i use wolfmpu, but the left shift problems exist still in this custom build
Back on time i use right shift, but i found left shift more confortable to my hands
Reply 3 of 11, by LSS10999
theelf wrote on 2024-04-15, 22:11:
... I've been curious about this behavior for a long time... what exactly could be causing it and why is it associated with NUMLOCK?
I noticed another behavior, however... that if you set Left Shift as run, it'll stay "pressed" until you press Right Shift, effectively making it a "walk" key similar to some other games.
On the other hand, this always-run behavior becomes a bit unstable if you run in a Windows DOS box.
Reply 4 of 11, by theelf
LSS10999 wrote on 2024-04-17, 14:21:
... I've been curious about this behavior for a long time... what exactly could be causing it and why is it associated with NUML […]
Hi, i was going to explain, but the member K1n9_Duk3 did very well here
Strange Doom + Wolf3D cursor/shift key mix-up in MSDOS 7.1
Reply 5 of 11, by badmojo
theelf wrote on 2024-04-17, 13:03:
Works fine for me.
Reply 7 of 11, by Gmlb256
I simply use the Z key for the Run action to get around this when using the oldschool controls in the DOS version of Wolf3D.
VIA C3 Nehemiah 1.2A @ 1.46 GHz | ASUS P2-99 | 256 MB PC133 SDRAM | GeForce2 GTS 32 MB | Voodoo2 12 MB | SBLive! | AWE64 | SBPro2 | GUS
Reply 8 of 11, by badmojo
theelf wrote on 2024-04-26, 16:10:
I tested 1.51 and left shift have the same problem regular wolf3d
From memory there are 2 options when using wolfmidi - classic controls or modern controls. Modern gives you WASD and some other changes, which is what I use. And left shift for run definitely works using this version.
Reply 9 of 11, by theelf
badmojo wrote on 2024-04-29, 00:17:
No, dont work like i said, test again. Wolfdosmpu still have same problem with cursor keys and left shift
Reply 10 of 11, by Gmlb256
theelf is right, the keyboard interrupt routine in wolfdosmpu is unchanged (aside from improving the Tab key handling) from the original source code.
The modern controls mitigate the problem because the WASD keys are taken account when one of the Shift keys are pressed, and the mouse is primarily used for rotation.
Reply 11 of 11, by badmojo
Got it. I've only used the modern control version, which I find to be a great improvement.
