Reply 40 of 55, by DoZator
A curious historical document that provides various examples of using DVI Dual-Link, for example:
As you can see, Dual-Link already worked in driver 53.03. Although at the beginning of this document, the driver version is mentioned as " 61.76 (IBM)". It turns out that it was some specific version of the driver, specially modified by IBM employees? Where can I download it today (I would like to see how it differs from the reference version from nVidia)? But in the 77.72 driver, support for this monitor has already been officially announced (It is possible that nVidia further implemented IBM employees ' developments in 77.72 or filed it itself). But I still believe more that the key to solving this whole story can be found in this very small box (Between the video card and the monitor), or rather in its EDID. Obviously, it is in it that something clearly indicates to the old video card that it is necessary to switch to Dual-Link mode (After all, the image should appear even before loading any driver, in normal conditions, even at the BIOS stage). If you take this EDID and modify it in a special way (For the actual capabilities of a modern monitor), you may get something useful (or maybe not).
Reply 41 of 55, by Jonsmith0815
DoZator wrote on 2024-04-30, 20:23:
What happens if you try driver 77.72 (Or earlier) for Windows XP? Will 144Hz work? Or do you need exactly "93.71" and higher?
By the way, the 300 series drivers for Windows XP support on-the-fly EDID redefinition for nVidia Quadro video cards, which greatly simplifies testing (this feature does not work on GeForce cards).
Newer drivers than version 84.43 dont support the 7 series.
The earliest driver I can test with a dual link card is 71.84 from 02/24/2005 with the Quadro fx 3450 pcie (late 6 series quadro).
I tested under XP today again a 7600gt agp and a Quadro fx 3450 pcie.
The 7600gt agp uses the earliest driver version 84.43 from 4/5/2006. It works at 144Hz. I tested it playing UT99 patch 469 and it works with vsync at 144fps. Earlier drivers don’t support the card. Unfortunately only 60Hz under 98 using the patched 81.98 drivers.
The 7800gtx uses the earlier 81.85 in xp from 12/10/2005, but i dont have that one.
But the problem is the fx3450: Only 60 Hz under 98, XP and 10.
I looked at the xp and 98 driver versions and they dont support always the same models.
For example there is no official support under 98 for the fx3450 with the latest 81.98 driver.
But under XP already the 71.84 driver supports it.
Under 10 with driver version 309, I tried CRU and Nvidia patcher, but only 60Hz was possible to select. Not possible to add custom resolutions, nvidia driver gives an error. Tried also the EDID override tool.
Under xp I can add 144hz using driver versions 71.98 and 84.43 in the Nvidia control panel and I can also select it and it seems to work. But when I play UT99 with vsync it’s only 60fps.
I tried d3d dx9 control panel refresh rate override to 120Hz (max) but still 60fps, also in OpenGL, also with refresh locker app.
Monitor also reports 60Hz. But control panel shows 144Hz. Very strange.
Using custom resolution in powerstrip i get only black screen.
It’s actually not easy to verify the refresh rate. For example testufo.com doesn’t work under XP, no matter what I tried with Firefox and chrome, the 7600gt only shows 60Hz, no idea why, but works at 144Hz in UT99. I guess the on screen display of the monitor tells the truth when it states 60Hz, I thought that was a bug.
The FX3450 has two dual link ports, it should work at 144Hz, so why doesn’t it work even under XP and 10?
Maybe I should try a later driver under XP. Like the version 185 you mentioned.
But it makes no sense because the 7600gt works perfect at 144hz in xp, why not the fx3450?
The fx3450 is a 6 series card (nv42gl), released before the 6800gs, xe and xt in July 2005.
Dual link was not integrated on the 6 series but only using an external chip.
Maybe the implementation of the external chip (TMDS) on the 6 series was not done correctly for high refresh ?
On the 7 series 7600gt dual dvi is integrated on the chip.
G70, G72, G73 models 7300 to 7800 have one integrated dual link port. 7800gtx released in June 2005, 7600 GT AGP in July 2006.
G71 models 7900 have two integrated dual link ports. 7900 GTX released in March 2006, 7900 GS AGP April in 2007.
I find it weird that the same xp driver version 84.43 supports dual link dvi high refresh only on the 7 series not on the 6 series.
It has to be the difference between the integrated and external TDMS chip.
This arcticle from 2004 also explains TDMS: https://www.tomshardware.com/reviews/tft-conn … tion,931-4.html
The fact that dual link high refresh support for the 6 series quadros wasnt even working in xp, makes me even more sceptical that there is a way under 98.
The problem is that dual link was introduced at the same time that 98 support stopped and didnt even work properly for high refresh until the 7 series in xp.
If you look at a gaming monitor from 2006, the viewsonic vx922 75Hz 1280x1024 2ms gaming monitor. It has only 75Hz. There were no monitors available that supported 144Hz at the time. So Nvidia couldn’t even test if the drivers work at full hd high refresh rates, because there were no monitors available. So I guess on many older cards like the 5 and 6 series the support for dvi dual link high refresh rates was just not there in the driver, because those external chips were only on a few Quadro cards and it wasn’t worth the work because nobody could use it anyway. Probably later drivers fix some of the problems for those older cards. I need to test that. But with the 7 series they integrated dual dvi on every card, so didn’t need to take care of external chips and I guess it was easy for them to implement it correctly for the whole series. At this point it started to matter, with better dvi tft displays becoming slowly available, and at the same time they dropped 98 support. So it seems that’s why dual link dvi high refresh was never possible under 98. But we haven’t tried everything yet, maybe it works on one of those other cards.
It’s a shame because it really makes a huge difference if you play UT99 at 60 or 144Hz. The fx3450 runs 1080p at over 300fps, the 7600gt even 600fps. So it’s really smooth at 144Hz. Of course we can play it under 10 or XP, but only under 98 we can have A3D, and I want both 😉
I wish I had a 2560x1440 dvi monitor so I could test those cards and drivers if they support only high resolutions but not high refresh.
Reply 42 of 55, by agent_x007
You could just run Vsync locked benchmark, with control scores for both 60FPS results and 144FPS one.
Assuming GPU can do more than 144FPS, if you get higher number of the two control scores - 144Hz mode should work properly.
Reply 43 of 55, by DoZator
The problem has already been successfully resolved. More precisely, I was solving a slightly different problem, but this one was also solved along the way. Now it runs 1920x1080@144Hz without any complaints under Windows 98 with the ForceWare 77.72 driver on the G70. I checked it in games with Vsync enabled and framerate unlocked. Indeed, a full-fledged 144hz and FPS counter and smooth movement show this. What exactly was the problem-I did not find out (It is possible that initially there was not a compatible EDID, or the adjustments made somehow affected it). I wanted to make DOS games run in a different video mode by default via the DVI port. I downloaded the reference EDID from the DVI-DL port of this monitor on GitHub and slightly modified it for this purpose. I added all available "Established Timings", slightly changed the "Standard Timings" at my discretion, and also manually registered in "Detailed Data" -> "Preferred Timing Block" the standard data from the online EDID calculator for 1600x900@72hz mode (So that under DOS it would always be at least 72hz at any time game via DVI connection), the rest did not touch anything. After flashing the DVI-DL port, it became - under DOS, all games are now scaled to 1600x900@72hz (Before that it was the same, only up to 60hz), - and Windows now runs 1920x1080@(100\120\144hz), which confirms the presence of a functional Dual-Link. These modes are specified in the EDID, in the section "CEA Extension" -> "Detailed Timing Blocks". It turns out that the video bios or driver still handles this extended block. In Windows 98, I cleared the PowerStrip config (It made negative adjustments due to previous, no longer relevant settings), reinstalled the driver, added 100\120\144hz to the registry, and also enabled monitor scaling:
    18.94 KiB
    15.65 KiB
    81.49 KiB
Reply 44 of 55, by DoZator
Jonsmith0815 wrote on 2024-05-21, 01:35:
If the video card doesn't support Dual-Link, it's likely that no driver can cure it. The video card can be tested in Windows XP with later drivers (185.20 and higher) that successfully handle even EDID curves (As was the case in my case). Also, under XP, it is possible to override the EDID on the fly, which allows you to check it without flashing it to the monitor (The function is available for Quadro video cards with drivers 257.21 or higher).
Reply 45 of 55, by Jonsmith0815
DoZator wrote on 2024-05-22, 09:26:
Awesome! That's so great that you could solve it!
Can you describe how you flashed the EDID of the XL2411?
I would like to flash my XL2411 as well 😉
Reply 46 of 55, by DoZator
Jonsmith0815 wrote on 2024-05-22, 12:04:
Awesome! That's so great that you could solve it! […]
As for flashing, taking into account all the risks, I remember how at the beginning of this (Or somewhere in the next) topic they suggested using the "EDID-EMULATOR"-a small programmable device connected between the monitor and the video card, which allows you to easily and simply switch several pre - prepared EDID overlap profiles. Something like this:
https://www.startech.com/en-us/audio-video-pr … ducts/vsediddvi
The main thing is to first check that Dual-Link is supported and all modes are transmitted correctly. I haven't tried anything like this yet, but even, for example, a simple KVM-Switch passed only a Single-Link through itself, so you need to be more careful when choosing such things (The fact that the link above is only for an example of how it may look in principle, but in no case is there a guarantee that it is at least like- then it will work and even more so support Dual-Link).
Nevertheless, in case of confirmation of full functionality, one of these pieces seems to be the most interesting and preferable solution, since it would allow you to easily and quickly change any pre-prepared modes, which is useful, especially in MS-DOS.
Regarding the firmware of the monitor itself, I used EDID-RW, following the instructions from GitHub (a pretty good step-by-step guide). In addition, a nuance surfaced - at the last step (Before entering the firmware command), you need to turn off the monitor. After that, just press "ENTER" and wait a little while until the firmware process is completely completed there and only then turn it on. In the monitor's service menu, the "Burn-in" option was previously enabled (It seems that it is also needed).
Previously, I tried flashing through the old version of PowerStrip under Win9x, but I didn't succeed then (Although at that time I still didn't know about the nuance with the need to turn off the monitor, maybe that's why). In the future, I didn't try using PowerStrip (I need the old unlocked version there, but it also turned out to be so buggy, besides. Moreover, there was already a ready-made and proven firmware tool at hand at that time).
darry wrote on 2022-10-25, 18:15:
That 2560x1600@60 limitation over dual-link DVI is often mentioned in DOCs [1] and ads, but detailed exact timings are not menti […]
The Serpent Rider wrote on 2022-10-25, 17:06:
In the first message, I indicated that when a modern video card is connected, DVI Dual-Link works in full. That is 1920*1080@144hz.
AFAIK Nvidia DVI connector of that era can handle 2048x1536@85Hz or anything that can fit into that bandwidth range (2560x1600@60 as mentioned above), but no more than that.
That 2560x1600@60 limitation over dual-link DVI is often mentioned in DOCs [1] and ads, but detailed exact timings are not mentioned (at least I haven't seen them), but I'm guessing at CVT-RB, so maybe 268MHz or so as calculated by [2] .
Maybe the TMDS and accompanying logic in the the 7950GT (and other similar GPUs) are either limited to 268-ish MHz and/or aren't flexible enough to handle what would have been, at the time, oddball timings like 1920x1080@144Hz .
OP could try setting up custom resolutions/timings with reduced blanking to test (trial and error) how far things can be taken. This is assuming the Nvidia drivers of the time allow this or that a third party tool like Powerstrip is used .
EDIT : Maybe the old Nvidia driver is trying to push wacky timings with huge blanking intervals that exceed even 330MHz by default .
[1]
https://www.evga.com/products/specs/gpu.aspx? … 6D-E9455529E242
[2]
https://tomverbeure.github.io/video_timings_calculator
I looked at EDID and for 1920x1080@100hz and 1920x1080@120hz it uses the classic CVT-RB, which fully corresponds to the values that the EDID calculator calculates, but for 1920x1080@144hz the values are very close to CVT-RB, but still slightly different from everything that the calculator has. Nevertheless, the nVidia driver for Windows 98 normally now accepts both the usual CVT-RB and even this custom mode from the monitor manufacturer. In the dual channel mode of operation under 9x it still remains in the range of 330MHz:
Reply 47 of 55, by Jonsmith0815
Thank you for the detailed explanation!
I will try edid-rw as well.
Could you copy and paste the contents of the EDID file you flashed?
I might not flash the same file, but use it only for reference when editing my EDID file.
Reply 49 of 55, by DoZator
Jonsmith0815 wrote on 2024-05-23, 11:28:
Thank you for the detailed explanation! […]
Yes, of course, but I'm still experimenting with refining the EDID and have recently made and already switched to a newer version of "EDIDM5.bin".
All changes (relative to the reference version) in "EDIDM4.bin":
* In the "Established Timings" section
- All existing modes are added
* In the "Standard Timings" section
- Replaced:
1920x16:9@60Hz -> 1600x16:9@100Hz
800x4:3@120Hz -> 800x4:3@100Hz
1024x4:3@120Hz -> 1024x4:3@100Hz
1280x5:4@60Hz -> 960x16:9@100Hz
1280x5:4@120Hz -> 1280x16:9@100Hz
1440x16:10@120Hz -> 1440x16:10@100Hz
640x4:3@120Hz -> 640x4:3@100Hz
- Added:
720x5:4@100Hz
* For DOS (Section "Detailed Data" - > "Preferred Timing Block")
- Replaced:
1920x1080@60hz [CEA-861\DMT] -> 1600x900@72hz [CVT] ***
* For Windows (Section "CEA Extension" - > "Detailed Timing Blocks")
- No changes
What has changed (compared to "EDIDM4. bin") in "EDIDM5. bin":
* In the section" Established Timings "
- Removed some exotic modes:
-- 640x480@67Hz [Apple, Mac II]
-- 832x624@75Hz [Apple, Mac II]
-- 1024x768@87Hz [IBM - Interlaced]
-- 1152x870@75Hz [Apple, Mac II]
- Changed the "Refresh Rate" for all existing modes to standard 60Hz
- No changes (?)*
- Added new modes (For native support)**
-- 960x540@60Hz [CVT-RB]
-- 960x540@100Hz [CVT-RB]
-- 1600x900@100Hz [CVT-RB]
*** For more information, visit https://tomverbeure.github.io/video_timings_calculator
** Now in Windows, three added new modes work natively (As is), without forced scaling by the video adapter to 1920x1080 (As was the case in the previous version of "EDIDM4").
* Major changes were made in the previous version (Described above). This section has not yet been discussed in more detail. It is planned to test a few more ideas regarding the use of multiple video modes under DOS in the future. I came across several EDIDs from other monitors that use not one, but several blocks at once in this section, with different values in each of them. If everything works out, it may be possible to change modes in DOS (If the video bios understands this, although, in theory, it should, because the Dual-Link monitors from Apple, in which I saw this, were released just around the same time). In addition, I am interested in the question of why the "Established Timings" and "Standard Timings"sections are ignored under DOS at all. Instead, go straight to "Detailed Data" -> "Preferred Timing Block" and take the mode from there (Including the refresh rate). And then any set video mode is converted to the one that was taken earlier from "Detailed Data" - > "Preferred Timing Block". It's not very clear yet.
What a cherry on the cake:
    EDID.zip
    1.18 KiB
    7 downloads
Reply 50 of 55, by Jonsmith0815
Just got EDID-RW running under linux mint live usb on my ryzen machine.
The output seems to be identical to your Reference_XL2411Z_DVI_binary.dat:
sudo ./edid-rw 7 | edid-decode
edid-decode (hex):
00 ff ff ff ff ff ff 00 09 d1 31 7f 45 54 00 00
21 19 01 03 80 35 1e 78 2e 9d e1 a6 54 54 9f 26
0d 50 54 a5 6b 80 d1 c0 45 7c 61 7c 81 80 81 bc
95 3c 31 7c 01 01 02 3a 80 18 71 38 2d 40 58 2c
45 00 13 2a 21 00 00 1e 00 00 00 ff 00 52 38 46
30 30 39 35 39 53 4c 30 0a 20 00 00 00 fd 00 38
90 1e a0 21 00 0a 20 20 20 20 20 20 00 00 00 fc
00 42 65 6e 51 20 58 4c 32 34 31 31 5a 0a 01 ae
02 01 04 00 fe 5b 80 a0 70 38 35 40 30 20 35 00
13 2a 21 00 00 1a 86 6f 80 a0 70 38 40 40 30 20
35 00 13 2a 21 00 00 1a fc 7e 80 88 70 38 12 40
18 20 35 00 13 2a 21 00 00 1e 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 c7
Block 0, Base EDID:
EDID Structure Version & Revision: 1.3
Vendor & Product Identification:
Manufacturer: BNQ
Model: 32561
Serial Number: 21573
Made in: week 33 of 2015
Basic Display Parameters & Features:
Digital display
Maximum image size: 53 cm x 30 cm
Gamma: 2.20
DPMS levels: Off
RGB color display
Default (sRGB) color space is primary color space
First detailed timing is the preferred timing
Color Characteristics:
Red : 0.6503, 0.3291
Green: 0.3310, 0.6220
Blue : 0.1513, 0.0527
White: 0.3125, 0.3291
Established Timings I & II:
IBM : 720x400 70.082 Hz 9:5 31.467 kHz 28.320 MHz
DMT 0x04: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz
DMT 0x06: 640x480 75.000 Hz 4:3 37.500 kHz 31.500 MHz
DMT 0x09: 800x600 60.317 Hz 4:3 37.879 kHz 40.000 MHz
DMT 0x0b: 800x600 75.000 Hz 4:3 46.875 kHz 49.500 MHz
Apple : 832x624 74.551 Hz 4:3 49.726 kHz 57.284 MHz
DMT 0x10: 1024x768 60.004 Hz 4:3 48.363 kHz 65.000 MHz
DMT 0x12: 1024x768 75.029 Hz 4:3 60.023 kHz 78.750 MHz
DMT 0x24: 1280x1024 75.025 Hz 5:4 79.976 kHz 135.000 MHz
Apple : 1152x870 75.062 Hz 192:145 68.681 kHz 100.000 MHz
Standard Timings:
DMT 0x52: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz
GTF : 800x600 120.000 Hz 4:3 77.160 kHz 83.950 MHz
GTF : 1024x768 120.000 Hz 4:3 98.760 kHz 139.054 MHz
DMT 0x23: 1280x1024 60.020 Hz 5:4 63.981 kHz 108.000 MHz
GTF : 1280x1024 120.000 Hz 5:4 131.640 kHz 233.793 MHz
Show last 29 lines
    GTF     :  1440x904   120.000 Hz  16:10  116.280 kHz 230.700 MHz
GTF : 640x480 119.999 Hz 4:3 61.800 kHz 52.406 MHz
Detailed Timing Descriptors:
DTD 1: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz (531 mm x 298 mm)
Hfront 88 Hsync 44 Hback 148 Hpol P
Vfront 4 Vsync 5 Vback 36 Vpol P
Display Product Serial Number: 'R8F00959SL0'
Display Range Limits:
Monitor ranges (GTF): 56-144 Hz V, 30-160 kHz H, max dotclock 330 MHz
Display Product Name: 'BenQ XL2411Z'
Extension blocks: 1
Checksum: 0xae
Block 1, CTA-861 Extension Block:
Revision: 1
DTD 2: 1920x1080 99.930 Hz 16:9 113.221 kHz 235.500 MHz (531 mm x 298 mm)
Hfront 48 Hsync 32 Hback 80 Hpol P
Vfront 3 Vsync 5 Vback 45 Vpol N
DTD 3: 1920x1080 119.982 Hz 16:9 137.260 kHz 285.500 MHz (531 mm x 298 mm)
Vfront 3 Vsync 5 Vback 56 Vpol N
DTD 4: 1920x1080 144.001 Hz 16:9 158.113 kHz 325.080 MHz (531 mm x 298 mm)
Hfront 24 Hsync 32 Hback 80 Hpol P
Vfront 3 Vsync 5 Vback 10 Vpol P
Checksum: 0xc7
I will now try to edit and flash the EDID
Reply 51 of 55, by Jonsmith0815
Wow, it works!
I flashed your EDIDM5.BIN, since the only difference seemed to be the serial number and week of production, otherwise my EDID was identical. And yes, it works! 1080p@144Hz tested with Vsync in UT99! It’s amazing!
Using 7600gt and 77 drivers. Ran 100Hz on startup. Had to enable the refresh using powerstrip with your settings.
Thank you so much! Before I thought I would never get this to work! And I didn’t believe that EDID was the solution!
Before I tested it on the FX3450 and it didn’t work. Not sure what the issue is. I stated above that dual link doesn’t even work under xp and 10 with the FX3450, but it turned out that it has only one dual link port and one single link, other than the Wikipedia page says, and I was using the single link before. Still with the EDID change i only got the same 120Hz only under XP as before with the old EDID.
What program did you use to edit your EDID?
Reply 53 of 55, by DoZator
Jonsmith0815 wrote on 2024-05-27, 16:13:
Wow, it works! I flashed your EDIDM5.BIN, since the only difference seemed to be the serial number and week of production, other […]
Wow, it works!
I didn't use PowerStrip. No special actions are required. 1920x1080@144Hz is selected normally in the nVidia control panel:
This video mode must be added to the registry:
REGEDIT4
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Display\0001\MODES\32\1920,1080]
"ModeRefreshRateList"="100,120,144"
Instead of "0001", you can have something else.
To edit the EDID, I used "AW EDID EDITOR 02.00.13" (Win98 with latest KeX or higher).
As for "EDIDM5.bin", is an experimental version provided as an example. It still requires improvements. First, it would be good to find out what are the best timings for DOS supported by the video bios of older video cards (Now the classic "CVT" is used for DOS). For LCD displays, it is probably preferable to use "CVT-RB", "CVT-RB v2" or custom timings (which the manufacturer uses for 1920x1080@144Hz for example in this case), achieving the shortest blanking time. The main thing is that vBIOS can understand this. This is the minimum.
Yes, this is also confirmed by information from GpuReview.com (Only one DVI-DL + DVI-I).
You can also do this for a guarantee in addition (So that the Dual-Link mode is always correctly applied by the video driver immediately, each time you log in to the system):
- create a new shortcut;
- save to it C:\WINDOWS\RUNDLL32.EXE NvCpl.dll, dtcfg setmode 1 1920 1080 32 144
where "1" is the target display number;
- move this shortcut to the folder "Start -> Programs -> StartUp"
So, each time you log in, the video driver will automatically apply the specified video mode. Even if the last one, before completing the work, was some other one.
Reply 55 of 55, by Jonsmith0815
DoZator wrote on 2024-05-29, 12:34:
- create a new shortcut; - save to it C:\WINDOWS\RUNDLL32.EXE NvCpl.dll, dtcfg setmode 1 1920 1080 32 144 where "1" is the targe […]
This does not work for me using the 82.69 driver. Haven’t testet it with version 77 yet.
When I execute the shortcut I get an error message (no entry in NV…).
I tested successfully also the 7900GTO at 144Hz using the patched 82.69 driver. But it has more problems than the 77 driver I believe. Quite often I get a black screen after resolution changes and on startup. Unplugging the cable and using VGA to change the settings helped. I don’t know what goes wrong there, it takes a lot of time and many restarts, I haven’t tested much.
Also I have a weird issue that I can no longer run UT99 with 144FPS both with the 7900GTO and the 7600gt agp. I had to reinstall some things and stability issues and I don’t know what has changed, but it only runs at 120FPS. I am quite sure I had tested it at 144FPS before. I am using Direct3D, and there seems to be a limit within DirectX for 120Hz. It can be changed using the directx control panel but 120Hz is the max I believe. OpenGL has bad performance, less than 90FPS. Not sure what settings I was using before. Maybe changing back from 82.68 to 77 would help.
I will test more cards and also driver version 77.
Also I am a little bit confused why the 77.72 drivers support the fx4500 and the 7600gt. They are not listed for the win98 driver, only for the xp driver as far as I know.
I stated above that 144Hz works for me using 7600gt with 77.72 drivers, but I think I was using 7600gt with 82.69 and fx3450 with 77.72.
