First post, by arablizzard2413
Here are two problems I've noticed so far:
1) When autolock=false, mouse movement is slow on the y axis, 2 times as fast on x axis. When autolock=true cursor movement is perfectly fine, same goes for fullscreen.
2) Using the S3 864 1.41B5 drivers, I'm getting weird pallet update problems with video for windows (see attachment). Just noticed it when I tried to play the King's Quest VI intro
(unrelated)
S3 Trio765 1.70.04 drivers throw a bunch of errors to the console when trying to play videos, all windows cursors turn black afterwards. Same pallet bug, but otherwise work fine.
Reply 2 of 16, by arablizzard2413
Yep, it's 640x480 256 colors, and they're the drivers from the running win 3.x on dosbox guide.
Reply 3 of 16, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
3) is the non-present S3 streams processor...
Did this video work in 0.72?
1+1=10
Reply 4 of 16, by arablizzard2413
Yes, it did. I've used this same Windows folder on past versions of dosbox and it's worked fine.
Reply 5 of 16, by wd
Rank DOSBox Author
DOSBox Author
Are you compiling dosbox yourself? Handy with cvs checkouts?
Reply 7 of 16, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Do you happen to have some small video file that shows this bug?
1+1=10
Reply 8 of 16, by arablizzard2413
do you mean a video of the bug happening in dosbox, or a sample from the clip?
Reply 9 of 16, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The latter
1+1=10
Reply 10 of 16, by arablizzard2413
Hmm, I tried spitting it up but I guess video editors don't expect 256 color avi files anymore. It didn't copy the other pallets, so would it be alright if I just posted the original video? I don't have another video on hand, I'm in the college cafeteria right now.
http://www.mediafire.com/?62jytmlccee - 12.5 MB
Reply 11 of 16, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Ok nice. I thought the file was 140 MB or something 😉
1+1=10
Reply 12 of 16, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Hmm nothing obvious... it "simply" forgets to update the palette.
As a workaround you can watch it in fullscreen or in 32/64k desktop color mode
1+1=10
Reply 13 of 16, by arablizzard2413
Well it's the intro for a game that requires 256 colors, so it's not really possible to do that when it plays. But if that's all that can be done, I guess I'll just have to live with it 😉
Reply 14 of 16, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
For me it's also broken in 0.72...
1+1=10
Reply 15 of 16, by wd
Rank DOSBox Author
DOSBox Author
So it'd behave the same on a real s3 card, right?
Reply 16 of 16, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Could depend on values that are read from the card...
1+1=10
