First post, by nxgtrturbo
Hi, this is my first post here, I am Nx GT-R, I am an OpenSource developer, I love cars, and I am trying to play/use a racing car simulator that I used to play/use in XP
(I write play/use since that isn't a game, but in same way could be called like that)
Software name: CarTest 4.5
Download URL: http://www.cartestsoftware.com/cartest4.5/dow … ads/CarTest.zip
Screenshots: http://www.cartestsoftware.com/cartest4.5/index.html
I am working under Freespire 2.0 (Ubuntu Core), and Installed the latest version of Dosbox (0.72), when I try to run the EXE I just got a tiny red-line square and then come back to ms-dos prompt, I am almost sure this is a “known issue”, I don't think this could be a “new bug”, I am just wondering if someones got the same and if there is something I could do
Thanks in advance.
http://systemarpi.googlepages.com/
Reply 1 of 4, by MiniMax
Rank Moderator
Moderator
Works mighty fine for me. I am attaching a script for unpacking and running CarTest 4.5 and the DOSBox configuration file that goes with it.
Note: You will have to edit the run.sh script and provide the correct path to your DOSBox install.
Edit: Updated the archive with new run.sh
    DOSBox-setup.zip
    1.27 KiB
    404 downloads
    Script for unpacking and running CarTest 4.5 and the DOSBox configuration file that goes with it.
_________________
Reply 2 of 4, by MiniMax
Rank Moderator
Moderator
Updated the archive with new run.sh.
_________________
Reply 3 of 4, by nxgtrturbo
Thanks for your help but I got the same exact problem, what I did was:
whereis dosbox (to know wheres my dosbox)
then I got: dosbox: /usr/bin/dosbox
so I replace the script line to:
dosbox="${DOSBOX:-/usr/bin}/dosbox"
(I guess that was right since the dosbox console was opened)
Then ./run.sh
Everything was ok, and the dosbox console was open showing everything was done and finally:
Type CT to start the simulation
(so I know that the dosbox.conf was found too since that message is there)
I got the same little square (I tried at fullscreen too), I upload the picture I got.
By the way, I don't know if this matters but I got this when calling dosbox
DOSBox version 0.72
Copyright 2002-2007 DOSBox Team, published under GNU GPL.
CONFIG:Loading primary settings from config file dosbox.conf
ALSA:Can't subscribe to MIDI port (65:0) nor (17:0)
MIDI:Opened device:none
Thanks in advance
    44.6 KiB
    This is what I got
Reply 4 of 4, by nxgtrturbo
Thanks a lot! with the new script everything was perfect, I notice you change the last line, hehehe cool, thanks a lot, I update the database with a lot of more cars if someones cares, heres the DAT file.
Nx GT-R
    CT.DAT.tar.gz
    70.33 KiB
    390 downloads
    222Kb Updated Database by Nx GT-R
