Reply 80 of 90, by ediflorianUS
2mg wrote on 2023-07-09, 20:14:Slight necro, but can someone ELI5 how did pre-C2D Intels with 2 "cpus glued together" actually handle FSB?
Did they share it, aka could one "core"choke the other, or was is 1/2 FSB speed split per "core"?
they where not glued together , 1 PCB , 2 dies (worked like dual Xeon 604)
https://cpumuseum.jimdofree.com/museum/intel/pentium-d/
https://www.bit-tech.net/reviews/tech/cpus/in … 4_670_pd_820/1/
and BTW , under early winXP versions , early vista and even some early 32 bit win7 , in day to day bassis Pentium D series , based on Netburst would handle better than C2D , not to mention posiblity of HT.
