First post, by arablizzard2413
I have some games where in the installation I select midi or adlib. I use launchpad and make sure all of the settings are correct yet the game still uses the internal pc speaker, when on a real dos os (with the same sound card) it plays using the speakers. My suggestion is this: enable pc speaker to wav/midi/mp3/adlib or whatever, so the game doesn't hurt your ears as much. The games I'm refering to are (this has nothing to do with asking for support, just a suggestion) Indiana Jones and The Fate of Atlantis, Elfland (old game not widely heard of), and most of the Super Solvers series. Please consider adding a pc speaker converter.
Reply 1 of 8, by vladr
Indiana Jones (both Holy Grail and Fate of Atlantis) should work with AdLib and/or MIDI, not speaker.
In the LaunchPad "VDMSound shortcut"'s properties add "a" or "r" (without the quotes) under the "parameters" section for atlantis.exe to force it to use AdLib or Roland/MIDI. If that still doesn't work then VDMSound is being interfered with by giveio.sys (see VDMSound FAQ).
Cheers,
V.
Reply 2 of 8, by Snover
Still, vlad, I would like to see some PC speaker support (especially for titles that use TrueSound).
Yes, it’s my fault.
Reply 3 of 8, by vladr
DosBox, DosBox, DosBox. PC-Speaker emulation is too tightly integrated with the PIT emulation in Winblow$ for me to mess with it.
V.
Reply 4 of 8, by Snover
DosBox DosBox DosBox doesn't run a lot of the games that I want to use.
Yes, it’s my fault.
Reply 5 of 8, by vladr
Yes, but if the effort required to implement PC-Speaker emulation under M$ Winblow$ were put into Dosbox instead then Dosbox *would* run a lot of games that you want to use. 😀
Reply 6 of 8, by Snover
Except you don't program for DosBox, so that analogy doesn't work.
Yes, it’s my fault.
Reply 7 of 8, by vladr
No, I don't, but I'm trying to get that MT-32 stuff off the ground, and on top of that I'll be very busy in the coming months at work, so I really don't feel like PC-Speaker emulation right now. :p
Cheers,
V.
Reply 8 of 8, by Snover
Well get one of them done soon or sooner!
Yes, it’s my fault.
