I've looked at this topic as it went by, of a bit of interest because I do know floppy drives on the PC quite well, but I've not posted here because I do not know this board at all (in fact I didn't know this existed)
The original PC design only wired the FDC for 2 drives, and in fact used the other drive select lines for other things (like drive-dependant motor-on)
As a result of this, I've never seem a BIOS supportine more than four drives.
-- I do switch drives quite a bit... As the developer of ImageDisk, naturally I tend to work a lot of different and non-standard(to PC) drives (anyone else have an 8" drive on your PC)
My usuall approach is to use a long FDC cable, and move the A: connector to the middle, so B: can be at the end (two twists around the middle connector). With the original ImageDisk system used a 37-Pin 'D' connector in a slot to make the external cable easily accessible from outside the case - after I sold that system and build a new IMD system on a block of wood, I just have the end of the floppy cable come out the side:
Re: Windows 95 on a Breadboard
This cable has the standard 5.25" and 3.5" drive connectors, and I have made adapters to allow connection of other drive types.
-- I have in some cases made up special cables (for others) with connectors for more than 2 drives - and front (or back) panel switches to select different drives to show up as A: (or B:)
-- I am curious, how does this type of board make all 4 drives accessible? Does it contain a BIOS extension?
How do you get it to work with operating systems which load their own drivers and don't use BIOS for floppy access? Do many of the OS companies/groups provide drivers for it?
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
