Reply 20 of 47, by myne
Update.
This guy made a better svga driver: https://github.com/PluMGMK/vbesvga.drv
So, I f'd around and added it.
1) unless stated otherwise the above list applies
2) I set the default to 1024x768x8bit.
3) There are only 4 display modes in the initial setup because the inf was a pain in the ass
4) Workaround: copied "oem0.inf". modes changable in "Windows setup".
5) added shortcut to show the available video modes before you change it "Video modes"
6) Keep an eye on that github page. New versions are likely.
7) If they do updates, copy files into windows dir, and (if he makes one) rename oemsetup.inf oem0.inf
😎 feel free to edit oem0.inf - it should be fairly self explanatory to add whatever random missing modes your setup supports that I left out.
9) To add VESA modes to Oracle virtualbox: C:\Program Files\Oracle\VirtualBox>VBoxManage setextradata 311"CustomVideoMode1" "1920x1080x24"
(311 is the VM name)
Edit Opps.
Accidentally removed the tcp/servicepack stuff
Fixed
I built:
Reply 21 of 47, by CursedSilicon
Was the newest release tested on VMware? I tried running it but it seems to hang when it first tries to load Windows 3.11
Reply 22 of 47, by myne
No, but vmware does sometimes hang on boot as per Point 5.
A reboot or 2 fixed it for me back then.
I built:
Reply 23 of 47, by Ant_222
I am I right that this image requires an actual CD-ROM drive with a physical machine, and a virtual CD-ROM drive with a virtual machine? I have failed to use it with HP t5720, which has no CD-ROM, but can boot off USB, because the image tries to access an actual CD drive. Could a USB CD drive help?
Reply 24 of 47, by myne
I have no idea what it needs physically.
It's just a regular CD image with disk 1 of the dos 622 as the embedded boot floppy and a custom bat.
If you can get 622 booting from usb, you label it the same, copy the custom files, and probably edit the CD drive letter finding bit, I don't see why it wouldn't be possible to work.
That's probably the issue. It relies on mscdex to get the drive letter to start the next bit.
I haven't looked at it in a long time, but look at the bats. I think I probably used something like %cdrom% which could be set to something else like d: by editing it.
Alternately... Its dos/3.11. There's f all to break.
Install on vm, copy to usb, sys c:, copy to hdd.
I built:
Reply 25 of 47, by honeynutz
Im having trouble opening your zip attached here -- it seems to be corrupted. Can anyone confirm?
Reply 26 of 47, by myne
I opened it fine on my phone.
I built:
Reply 28 of 47, by ideasman69
Thanks so much for this.. i've been trying to do this myself with no luck.
Can i ask what the secret sauce is that allows the dos setup to work properly? Whenever i tried to make a dos cd-rom installer, i either got the "insert disk 1 into d:" message or it would get through the first "disk" and then ask me to insert disk two.
I've poked through the autoexec.bat and setup.bat files but cant seem to find the answer
Reply 29 of 47, by myne
I can't remember any problems except the "boot floppy" partition label. It had to be that exact name.
The rest was just copying the files into the folder.
I built:
Reply 30 of 47, by ideasman69
I’ve been slowly REM’ing stuff out of autoexec and it’s now broken. So there’s something in there that’s allowing it to work
I’ll keep at it as my OCD won’t let it go
Reply 31 of 47, by myne
Not remembering or seeing any real magic here.
I believe it is just the disc label.
@ECHO OFF
cls
set temp=c:\
set tmp=c:\
path=a:\
set formatted=no
smartdrv
IF "%config%"=="NOCD" GOTO QUIT
LH MSCDEX.EXE /D:oemcd001 /L:D
IF "%config%"=="SETUP_CD" goto AUTOSETUP
GOTO QUIT
:AUTOSETUP
set CDROM=FOO23
if exist z:\w311.cd set cdrom=z:
if exist y:\w311.cd set cdrom=y:
if exist x:\w311.cd set cdrom=x:
if exist w:\w311.cd set cdrom=w:
if exist v:\w311.cd set cdrom=v:
if exist u:\w311.cd set cdrom=u:
if exist t:\w311.cd set cdrom=t:
if exist s:\w311.cd set cdrom=s:
if exist r:\w311.cd set cdrom=r:
if exist q:\w311.cd set cdrom=q:
if exist p:\w311.cd set cdrom=p:
if exist o:\w311.cd set cdrom=o:
if exist n:\w311.cd set cdrom=n:
if exist m:\w311.cd set cdrom=m:
if exist l:\w311.cd set cdrom=l:
if exist k:\w311.cd set cdrom=k:
if exist j:\w311.cd set cdrom=j:
if exist i:\w311.cd set cdrom=i:
if exist h:\w311.cd set cdrom=h:
if exist g:\w311.cd set cdrom=g:
if exist f:\w311.cd set cdrom=f:
if exist e:\w311.cd set cdrom=e:
if exist d:\w311.cd set cdrom=d:
if "%CDROM%"=="FOO23" goto NOCDROM
path=a:\;%CDROM%\
cls
@echo.
@Echo After the first part of the DOS setup:
@Echo It is normal to say "Invalid media type reading drive C" here.
@echo Press A if it happens
if exist c:\io.sys set formatted=yes
if %formatted%==yes goto skipformat
:formatit
format c: /autotest >nul
copy a:\io.sys c:\
if %formatted%==yes echo C drive is formatted
if %formatted%==yes echo Restarting in 5 seconds
if %formatted%==yes sleep 5
if %formatted%==yes restart
nlsfunc
keyb us
Echo About to start setup from a:
setup
Show last 13 lines
:skipformat
%CDROM%
setup.bat
goto QUIT
:NOCDROM
echo.
echo The Setup files were not found. xx
echo.
:QUIT
This, from the setup.bat looks like it might be the 'magic' you're looking for.
set path=a:\;c:\;%cdrom%;c:\dos
I built:
Reply 32 of 47, by CooperHowad
Hey, just reporting in to say that this worked very well on an old Compaq Deskpro with xfdisk for dualbooting. Still finishing everything up, but I tried a number of different methods to get a dual-boot setup with 6.22, 3.11, and 98SE and this is the best option.
I can confirm that, on real hardware, the 6.22 requires an unformatted drive.
Will update if there's anything to report.
Reply 33 of 47, by myne
Good to hear.
I didn't think I broke anything, but confirmation is nice.
I built:
Reply 34 of 47, by ldeveraux
henk717 wrote on 2025-03-28, 13:15:
Correct yes, I even redownloaded Windows 3.11 for Workgroups OEM as well as MS-Dos 6.22 in case it was an issue with my own version I already had.
When making the template disk I use ultraiso with the no to all option.
Wondering if you ever got this sorted? I know OP doesn't provide support, but I'm in the same pickle.
Reply 35 of 47, by myne
What's the issue?
Can you take pictures of your steps?
I built:
Reply 36 of 47, by ldeveraux
myne wrote on 2026-04-17, 05:43:
What's the issue?
My issue is the same as everything they wrote. Installed in Virtualbox and it won't boot past the WFW splash screen.
Reply 37 of 47, by myne
What LAN card is set?
Worth trying VGA mode and no lan in the windows\setup program from dos
I built:
Reply 38 of 47, by LSS10999
ldeveraux wrote on 2026-04-17, 13:39:
What's the issue?
If you've set up LAN chances are you'll run into the NDIS problem similar to that of Win95. Most recent patcher9x had supported this patch for WFW.
Though my experience on a real machine with a patched NDIS.386 and RTL8139 was that, while it can boot and run programs, trying to do any filesystem-related operations (WinFile or Calmira Explorer) immediately hangs the system.
Reply 39 of 47, by ldeveraux
LSS10999 wrote on 2026-04-18, 04:04:
What's the issue?
So reinstall again using VGA and no LAN? I don't think I setup LAN at all though...
