Replacing DOS/4GW with DOS32A
Reply 20 of 25, by sharangad
Doesn't work. There is an LE signature but it's not at offset 0x3C in the BW header:
C:\DOS\CR\CART. EXE
File size is 1247899
Exec 1
Signature: MZ
startVal as char
HeaderVal[0x18] : 0000001E, start val[0x3C]: 09B40000
Exec 2 is BW
HeaderVal[0x18] : 08183FFF, start val[0x3C]: 00009200
LE Signature missing
The LE signature occurs after a bunch of DOS4GW string later on.
[EDIT] I think I messed up the code translation.
[EDIT2] Nope, the exe defies analysis.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 21 of 25, by M-HT
Let's try more details.
In order to replace DOS/4GW from Indycar Racing 2 with Dos32A, first manually unbind the linear executable.
That means, make a copy of the original executable and remove first 0x28C9C (167068) bytes from the copy. The new file should begin with LE header.
Then bind Dos32A to the new file using "sb /b" or "sb /bs".
Reply 22 of 25, by sharangad
M-HT wrote on 2025-03-07, 15:46:
Let's try more details. In order to replace DOS/4GW from Indycar Racing 2 with Dos32A, first manually unbind the linear executab […]
OK that makes sense.
Reply 23 of 25, by sharangad
sharangad wrote on 2025-03-07, 15:57:
That worked! Thanks!
Reply 24 of 25, by techweenie
I released an updated version of DOS/32A and version 26.1 fixes this issue. Somehow all the id Tech games freeze on startup now, so once that's fixed I'll release 26.1.
https://github.com/calculatetech/dos32a
Reply 25 of 25, by sharangad
techweenie wrote on Yesterday, 16:36:
Thanks! I was able to extract the LE executable using Dos4GW Pro's toolset. I will give your updated build a shot soon, to see if it works.
