Reply 60 of 115, by ElTentakel
myne wrote on 2026-10-22, 02:17:
I was randomly looking at the code, and with my limited understanding it looks like there's some optimisations to be found. […]
This, at face value looks like an important function probably called a lot.
If it's not a hot path used thousands of times a second, it doesn't matter.
If it IS, then it looks like it should be broken into different functions and the correct one selected during init.
As an example, imagine I ask you to cut 5000 pieces of wood and you're an idiot that can only follow a flow chart.
Every time you are given a piece of wood, your first question is
"what is this?"
"Should I use scissors, a saw or a knife?"
Only after a bunch of decisions for EACH piece, do you start cutting.
IF this is a hot path, that's wildly inefficient.
You make the decisions first. Set up a cutting saw function, and just dump wood into the "in box".
Again, I could be very wrong. This could be the "upfront" decision tree and the actual drawing function is elsewhere, but it DOES SAY "Apply fog" which is what makes me think it is the thing that adds fog.
If I were to optimise it, I'd split it into "apply_no_fog", "apply_fixed_fog", "Apply_multi_fog" or something like that and then just set the correct one as your current "cutting saw" station and blindly feed it data.
Reusing code is often very useful. But there's a time and a place to get fancy with one flexible multitool, and a time to build 10 custom single purpose factories.
https://github.com/ElTentakel/Glidulator/blob … voodoo_render.h
#define APPLY_FOG(src_r, src_g, src_b, z, ia, w)  \
do { \
if (params->fogMode & FOG_CONSTANT) { \
src_r += params->fogColor.r; \
src_g += params->fogColor.g; \
src_b += params->fogColor.b; \
} else { \
int fog_r, fog_g, fog_b, fog_a = 0; \
int fog_idx; \
if (!(params->fogMode & FOG_ADD)) { \
fog_r = params->fogColor.r; \
fog_g = params->fogColor.g; \
fog_b = params->fogColor.b; \
} else \
fog_r = fog_g = fog_b = 0; \
if (!(params->fogMode & FOG_MULT)) { \
fog_r -= src_r; \
fog_g -= src_g; \
fog_b -= src_b; \
switch (params->fogMode & (FOG_Z | FOG_ALPHA)) { \
case 0: \
fog_idx = (w_depth >> 10) & 0x3f; \
fog_a = params->fogTable[fog_idx].fog; \
fog_a += (params->fogTable[fog_idx].dfog * ((w_depth >> 2) & 0xff)) >> 10; \
break; \
case FOG_Z: \
fog_a = (z >> 20) & 0xff; \
break; \
case FOG_ALPHA: \
fog_a = CLAMP(ia >> 12); \
break; \
case FOG_W: \
fog_a = CLAMP((w >> 32) & 0xff); \
break; \
fog_a++; \
fog_r = (fog_r * fog_a) >> 8; \
fog_g = (fog_g * fog_a) >> 8; \
fog_b = (fog_b * fog_a) >> 8; \
if (params->fogMode & FOG_MULT) { \
src_r = fog_r; \
src_g = fog_g; \
src_b = fog_b; \
} else { \
src_r += fog_r; \
src_g += fog_g; \
src_b += fog_b; \
src_r = CLAMP(src_r); \
src_g = CLAMP(src_g); \
src_b = CLAMP(src_b); \
…Show last 1 line
    } while (0)
I've tested it, but it seems that there is not much difference. It seems that the branch prediction is good enough, so there is no need to optimize the decision. And the JIT version doesn't even make those decisions, so there is no need to optimize it either. But thank you for sharing this idea 😀.
Reply 61 of 115, by ElTentakel
DoZator wrote on 2026-10-19, 10:17:
I tried the new version "0.9.2" on Windows 98, using "GLSMP.VxD" + "GLIDE2X.DLL" as an external library for DOSBOX-X, and it act […]
I tried the new version "0.9.2" on Windows 98, using "GLSMP.VxD" + "GLIDE2X.DLL" as an external library for DOSBOX-X, and it actually works in Multi Thread. Without any issues or glitches.
I also tested the same "PYL Demo" in the "BURNMEM + HIMEM + EMM386" configuration, together with HDPMI32I, since without it, GLIDULATOR still crashes in MS‑DOS mode when running this game, upon loading a save or the first level. The "CPUID Limit" is also enabled in the BIOS (disabled in parentheses). Results:
before launching Windows:
- 1 Core - HT = 1/1 Cores 14.7 FPS (1/1 14.7)
- 1 Core + HT = 1/2 Cores 14.7 FPS (1/1 14.7)
- 2 Core - HT = 1/2 Cores 14.7 FPS (1/2 15.1)
- 2 Core + HT = 4/4 Cores 29.6 FPS (1/2 14.7)
- 3 Core - HT = 3/3 Cores 29.5 FPS (3/3 30.3)
- 3 Core + HT = 5/6 Cores 30.3 FPS (3/3 29.5)
- 4 Core - HT = 4/4 Cores 45.3 FPS (4/4 45.2)
- 4 Core + HT = 5/8 Cores 29.9 FPS (4/4 45.3)
in Windows:
- only Single Thread (15.2 FPS);
after exiting Windows:
- without HDPMI32I and EMM386, Multi Thread works, but the game crashes when loading a level;
- works fine in both cases when combined with "HDPMI32I", but only in Single Thread mode (14.7 FPS).
The attachment PYL1.PNG is no longer available
The attachment PYL2.PNG is no longer available
The attachment PYL3.PNG is no longer available
Thank you for the screenshots and for adding a more visual indication of the flows. By the way, the statistics are not included in the screenshots, and it would be useful to have a switch "GLIDULATOR_SCREENSHOT=2" (Displaying statistics in screenshots). There is no explicit display of the current operating mode in a single letter - (R)ing0, (P)aging, (F)lat, (G)lsmp, or (O)ff.
It would also be good to add support for "GLSMP.VxD" at the same time in "GLIDE2X.OVL" for DOS games that work well on Windows. This feature would be very useful.
I've added your "GLIDULATOR_SCREENSHOT=2" recommendation for a next release.
Thanks you for testing. With CPUID Limit enabled Glidulator can't see which cores are HT and uses them as real cores. That is why 4 Core + HT is slower. Without the limit it works as intended. I will try to fix the detection and make tests with the PYL Demo.
Reply 62 of 115, by ElTentakel
I found out that too much memory was used by Glidulator, so the game ran out of RAM. I'm not sure if that fixes your issue completely, but we will see. The fix will be in the next release. I will post the next release here, then you can test it on your machine.
Reply 63 of 115, by myne
ElTentakel wrote on 2026-10-25, 16:22:
"what is this?"
do { \
} else { \
int fog_idx; \
} else \
fog_r -= src_r; \
fog_g -= src_g; \
fog_b -= src_b; \
case 0: \
break; \
case FOG_Z: \
break; \
case FOG_ALPHA: \
break; \
case FOG_W: \
break; \
fog_a++; \
src_r = fog_r; \
src_g = fog_g; \
src_b = fog_b; \
} else { \
src_r += fog_r; \
src_g += fog_g; \
src_b += fog_b; \
…Show last 1 line
    } while (0)
Fair enough. Compilers can be crazy efficient.
Also, I could have been wrong as I said.
If it only runs once it doesn't matter much.
Are you able to note something like the "hottest" 10 loops/functions with some counters based on say 2 minutes of game footage?
That might help people know where to look.
Most likely it will follow a power law with the hottest one being streets ahead.
Personally, I have a suspicion that some handcrafted sse/avx applied to 2-3 functions will make a drastic improvement.
But which ones are important?
I built:
Reply 64 of 115, by ElTentakel
Release v0.9.3 is out. It includes the fixes mentioned above and mipmap dithering. Unfortunately I have to change my test setup. I'm not able to test the HT detection with CPUID Limit and DOS after Windows 9x, since my little Shuttle PC is missing a PS/2 port. After switching, I'll return to that
myne wrote on 2026-10-26, 01:39:
I agree, I will have a look at it after getting another test system ready.
Reply 65 of 115, by RayeR
I tried under DOS now it can run also in v86 mode (jemm) on single core, as expected.
Reply 66 of 115, by DoZator
Thank you for the new release. GLIDULATOR is getting better and better with each new version!
My brief report on version 0.9.3:
The statistics display is now completely fine. And the screenshot function works correctly.
Regarding multithreading... Using the "PYL Demo" example, in version 0.9.2, with "CPUID Limit" enabled (disabled in parentheses), in the BURNMEM+HIMEM+EMM386+HDPMI32I configuration, the result was:
"2 Core + HT = 4/4 Cores 29.6 FPS (1/2 14.7)"
"4 Core + HT = 5/8 Cores 29.9 FPS (4/4 45.3)"
in version 0.9.3, it became:
"2 Core + HT = 1/2 Cores 14.7 FPS (1/2 14.7)"
"4 Core + HT = 4/4 Cores 45.3 FPS (4/4 45.3)"
Is it possible to add a switch for this behavior here? Something like "GLIDULATOR_HT=0|1". By default, at least at the current stage, it will be "0" (which corresponds to the current behavior of version 0.9.3). In the "2 + HT" configuration, the value "1" will be useful. It will also be useful for other test purposes. This setting doesn’t even need to be displayed in GLIDULAT.CFG right now; it can be mentioned only in MANUAL.TXT until "HT" support is fully implemented.
As for HDPMI32I. Without it, the GLIDULATOR with this game still crashes in this configuration. With it, everything works well, as before (in multithreaded mode).
In Windows, only one core is still available (glide2x.ovl).
After exiting Windows in MS-DOS mode, only one core is still available.
In the "BURNMEM+HIMEM only" configuration, the following differences are observed:
After exiting Windows in MS-DOS mode, multithreading works. The game no longer crashes without "HDPMI32I". But if you still add "HDPMI32I" here, the game starts running only in singlethreaded mode (before launching Windows in multi-threaded mode). It turns out that Glidulator, after exiting Windows, cannot use multi-threading in "paging" mode.
Reply 67 of 115, by ElTentakel
Thank you for testing. Yes, the latest version supports GLIDULATOR_HT, and I hope it works the way you intended. It also fixes some of the issues you reported, though running EMM386 without HDPMI32I still seems impossible for now. Thanks to the new test machine and a remote testing setup, I was able to fix many other problems like the Half-Life crash, which turned out to be a race condition. Because of this, I haven’t had time to work on performance yet, but those optimizations may come in the next release
Reply 68 of 115, by myne
Any word on which are the hottest codepaths?
I built:
Reply 69 of 115, by DoZator
ElTentakel wrote on 2026-11-04, 17:15:
Everything is fine; I don’t consider this to be a serious problem at all. "HDPMI32I" is a completely safe component that, when loaded into upper memory, doesn’t even interfere with Windows boot. Moreover, it can be unloaded at any time. So, if it’s required for operation in this mode, there’s nothing wrong with that. Otherwise, the behavior seems to match what’s stated in "CHANGES.TXT" and I haven’t noticed any deviations so far. In addition to the fact that "MANUAL.TXT" contains information that I cannot confirm, namely "...and in the DOS box of Windows, the OVL renders on one core with the C path;" but in my case, it’s "JIT" that works - at least, that’s what the statistics show. And this has been the case since the very first version. And yes, congratulations on moving to the new test platform. Thank you for the new release!
Reply 70 of 115, by myne
I have some random thoughts for you.
1) have a switch on load eg /cores 0111 or /cores 0011.
Use a binary mask because it's easier for people to understand. 0111 = cores 0 off (should always be off), cores 1,2,3 active.
/glcores 0111 = cores 0 off (should always be off), cores 1,2,3 active.
/glcores 0011 = cores 0,1 off (should always be off), cores 2,3 active.
I suggest this way, because I expect SOMEONE to copy this approach for sound. SBEMU/Picogus. If you can set the "standard" as it were, they are likely to copy.
eg /guscores 0100 would be compatible with glcores 0011.
Picogus is a fairly likely candidate since it has a great deal of functionality. cdroms, network etc.
2) It might be performance wise better to split the rendering a bit. Eg split the core workloads by function.
Example:
core1= render1 (sli? 1)
core2= render2 (sli? 2)
core3= scaling/antialiasing
I have no idea really, but I suspect antialiasing/scaling would be moderately high workload, and therefore run poorly on lower end machines.
3) I had a quick look at your recent changes in vid_voodoo_codegen_x86.h
It looks like you're targeting sse which is good.
It's worth noting that the first AMD64x2/core2 duo had SSE3. Anything before those is likely not performant enough to be worth targeting (Sorry BP6 bros).
In which case... it's worth considering making the worker payload entirely 64bit. I note you mention 16bit alignment in that file. I have no idea what the caveats may be here. I imagine there will be some hurdles, but I can't imagine they're insurmountable.
It may be worth having alternate paths that use AVX too.
I built:
Reply 71 of 115, by ElTentakel
The approach with the bitmask for cores is very good. I’ve experimented with 8 cores (including HT threads) by balancing the load based on estimated runtimes which improves performance a lot. I’ve also optimized the code and enabled the second TMU for Windows (sadly, DOS doesn’t have enough memory). Filters and FSAA have also been improved and are now distributed across all cores, so their impact is reduced. Overall, it may be possible to run this on a Core 2 Quad or even a very fast Core 2 Duo at the lowest settings, which would be great in my opinion. Since memory access seems to be the bottleneck, I will try to reduce it further. The next release will be dedicated to performance optimization. After that, I will try to test and improve compatibility.
Reply 72 of 115, by myne
What's the issue with memory?
Run us through how it allocates and interfaces back and forth
Thoughts on 64bit workers?
I built:
Reply 73 of 115, by ElTentakel
It’s about the memory that has to be visible to glide2x.ovl. It must be located in an area the overlay can access and that area is very limited. This was also the cause of the crash in Pyr, It simply ran out of memory because glidulator took all of it. There are some MBs I can save, but also two TMUs are not common for DOS games. Maybe I'll come back to that later.
Reply 74 of 115, by myne
How do the original cards do it?
Mimo? 12mb x2 in the pci space?
How big is a worker?
I built:
Reply 75 of 115, by myne
https://nand2mario.github.io/posts/2026/zsst-voodoo/
Have you read that?
I built:
Reply 76 of 115, by ElTentakel
no, but it is very interesting.
As far as I know the first two generations of Voodoos use a 16Mb BAR divided in 2 4xMB parts for control and LFB and a 8MB texture window. Every TMU in Glidulator needs 13MB but a worker only 130KB, since workers share most of the data. From what I understand every texture has a fixed size in the PCem code, so there is a little bit of optimization possible. But doubling workers will always be cheaper, if possible.
The new Release is out. I've tested also Redguard under DOS. It works well but it is far away from a Core2Duo 😁.
Reply 77 of 115, by myne
You haven't answered me on using 64bit code for workers!
Wouldn't it be generallyfaster?
Ok, so correct me if I'm wrong here.
A worker is a piece of code doing a bunch of effectively 32bit integer math (fixed point decimal with bit shifts)
You're working with CPUs that are a minimum of 40x faster (2+ghz vs 50/60mhz) than a voodoo, and memory that is much, much faster.
They also have a minimum of 2mb of cache.
SSE3 is a 16x8bit integer chewing machine. (RGBA,RGBA,RGBA,RGBA) 4 simultaneous pixels!
AVX is also an option on 2nd gen core and newer. I don't see why you couldn't use fixed point in an FPU. which would effectively double your fixed point.
IF this can't outpace a voodoo by 20x and the code is fairly optimised, it would seem that there's something causing cache misses/pipeline flushes
Just spitballing here, but maybe not enough data is being fetched at once. Since the voodoo is a pipeline working on 4 pixels simultaneously, maybe it wouldn't be insane to have multiple r,g,b,a pixels pulled at once into some kind of array?
Eg, r1,g1,b1,a1 ; r2,g2,b2,a2 ... r32,g32,b32,a32 (32 is an example)
So you fetch 32 pixels, process 32 pixels (256 bytes), and loop. This should theoretically reduce cache misses - no?
I built:
Reply 79 of 115, by myne
I... Don't see why dos or 9x would need to be aware of avx for a worker in a secondary core to use it?
Maybe I'm imagining this wrong.
Core o is the os. It talks 16/32bit to memory addresses reserved by the voodoo driver.
Cores 1+ are workers essentially running as though they are an independent addin card.
A code block is loaded into a block of memory that the os cannot access, and it is run continuously in a loop until explicitly told to stop. It has no io. A very restricted window of memory it can read and write to. A block of code. A block of "vram", and a block that both the driver and the worker can see for communication.
It's a microcontroller. Not a cpu at this point. Logically speaking, of course.
There is no logical reason this code cannot be full 64bit and exploiting every possible cpu function.
What am I missing here?
I built:
