First post, by brakenwagen
I am Trying to make star control 1 run on my computer using Dosbox ver .72. the game will run its just that there is absolutely no sound at all. Any suggestions would be appreciated.
Oh well, it's just a simple matter of adjusting your computer's flux capacitor to match the quantum range of the audio preprocessing unit #7 (1-6 won't work) using the values taken from the XSU that's posting messages. Do you have any cling wrap and a hammer? You're going to need them.
Yes, it’s my fault.
Try running the game with "starcon /s:adlib" instead of just "starcon".
I found out how get the sound up you set MPU-401 to none. I have no clue way this worked but it did. 😁
This issue came up recently (you may have found this other thread that explains about setting mpu401 to none, and why it works): Star Control 1 VERY Messed up Sound Effects...need help
The game's command line parameter works regardless of how the midi interface is configured in DOSBox.
