Across The Rhine 1944 by MicroProse
Reply 20 of 27, by MarkTK36thIL
Type at the Z:_
C:
Type at the C:_ CD 1944ATR line should read C:\CD 1944ATR press return
Type CD REQ line should read C:\1944ATR\CD REQ press return
Type install line should read C:\1944ATR\REQ\install press return
OK, at this point is when I start having problems.
The line that I'm typing reads C:\> of something like that. Then when I press enter, it says unknown or C isn't there. Please advise.
[/i]
Reply 21 of 27, by Qbix
Rank DOSBox Author
DOSBox Author
please mount the C drive first. Check the guides forum for the 60 seconds guide to dosbox.
Water flows down the stream
Reply 22 of 27, by MarkTK36thIL
C:\>CD 1944
C:\1944ATR>CD REQ
Unable to change to: REQ
I've read throught the directions for the REQ part, and I'm a little confused by it.
Am I taking all the files from the REQ folder already there -after I cut and pasted it into my C drive- and pasting it into the main ATR folder?
Reply 24 of 27, by MarkTK36thIL
0 Files are listed.
3 Dir 110,450,000 bytes free.
You'll have to be clear with directions, I've never really worked with DOS before.
Me = n00b
Reply 25 of 27, by wd
Rank DOSBox Author
DOSBox Author
Maybe you shouldn't play dos games if you never used dos before.
Or grab some old dos book you've of course lying around.
Reply 26 of 27, by MiniMax
Rank Moderator
Moderator
Are you a n00b that can read?
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
Reading the aptly named README file will be a good idea too.
_________________
Reply 27 of 27, by UK_John
I have reinstalled this following the instructions after a hard drive problem and I cannot get the game to see the digital side of the soundcard, but always finds the music side. After quite a while, I forget what I did to get it working, and in support of MarkTK36thIL the bit about copying the REQ files to REQ is a mite confusing. I am assuming a folder called REQ must be inside the folder called ATR?
EDIT: Got the sound working by reinstalling my drivers, so my baddie. I am so glad I have the manual though, as even after just 6 months or so I need to brush up on how to play the game! 😀
