First post, by silentwulf
Ok, I'm having a real hard time with the video codec that comes with DosBox.
I guess for starters, it wont install. I've used the shortcut given when you install DosBox to install the codec, but nothing happen. I even right click the INF file to install, and still nothing.
I tried the K-Lite codec pack, and while the files play in Windows Media Player, I can't edit the videos in either Sony Vegas or Windows Movie Maker.
I use a program called GSpot to detect what codecs a video file uses, and it states that ZMBV isn't installed.
Reply 2 of 9, by silentwulf
Fine;
DosBox 0.72
Vista Ultimate 64-Bit
I recently reinstalled my OS, upgrading from Vista 32-Bit. It used to work in my editing software. I just don't remember what I need to do to get it working properly.
Reply 3 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
ah yes. There should be some thread on installing zmbv on 64 bit vista.
It was recently fixed. Not sure if that thread contains the actual fix
Water flows down the stream
Reply 8 of 9, by l_mcgregoruk
I just tried to install the zmbv codec from 0.73 release from the start menu shortcut(Vista Ultimate 64-Bit). and I get an error box.
Copy Error
"An error occured while copying file zmbv.inf
Cannot copy file to destination directory.
Click Retry to retry the operation or cancel to"
Clicking Retry does nothing, but Clicking cancel says
Copy Error
"Do you want to continue Setup without copying this file?"
Clicking Yes here brings up another box
Error
"Installation Failed"
However if I manually copy C:\Program Files (x86)\DOSBox-0.73\zmbv\zmbv.inf to C:\Windows\inf\zmbv.inf it works fine.
Although copying it manually brings up two permission boxes
Destination Folder Acess Denied
"You'll need to provide administrator permission to copy to this folder"
and after that a normal UAC box.
Reply 9 of 9, by DosFreak
You need to right-click on the shortcut and choose "Run as Administrator".
You are installing something on your system so you need Administrator rights to do so.
Make your games work offline
