First post, by wolf
I am running Broken Sword, the sprites and any movement seems to jidder/stutter when moving around. Almost seems to flicker somtimes.
I tried diffrent Cycles from Auto and 20K up to 80K. No diffrence.
I also tried running the EXE with "-b" Didn't help like it did with "toonstruck" which solved the flicker issue completely.
Any suggestions?
Reply 1 of 16, by Vinx
You could try '=max' or '=auto' to 'cycles'; numeric value tends to cause stuttering.
Windows XP Professional sp.2
Core 2 Duo E4500 @2.33GHz
2Gb RAM, 320 Gb SATA-RAID0
Geforce 9800 GT 1Gb DDR3
SB X-fi Xtreme Audio
Reply 2 of 16, by wolf
I tried Auto, max and raised the values 20, 000 to 80,000.
And all stuttered the same. 80K seems best, less audio clicking.
Reply 3 of 16, by Vinx
Strange.. normally there should be a great difference in speed between numeric value and 'max'. This goes to conclusion that your problem is not the CPU working cycles. I noticed that your video card is Geforce. Your problem seems to converge mine (as you can see, I use 9800GT).
So, check out my thread about this here:-
DOSBox running slow with GF9
Reply 4 of 16, by Harekiet
Rank DOSBox Author
DOSBox Author
Cycles/videocard doesn't help, there seems to be some bug in dosbox with this game that it's drawing to the screen just as dosbox is updating it so you get half erased/half drawn sprites. Nothing you can do about it, use scummvm
Reply 5 of 16, by wd
Rank DOSBox Author
DOSBox Author
Used to work some time ago, not? Think i remember playing it in dosbox.
Reply 6 of 16, by wolf
Well if thats the case then I guess thats it. Hopefully this will get resolved in the next release.
Reply 7 of 16, by wolf
Now that 0.73 is released... does anyone know if there is a solution now? Thus far, same issue with the new release.
Reply 8 of 16, by wd
Rank DOSBox Author
DOSBox Author
[useless reply removed]
This has not been resolved.
Reply 9 of 16, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Seems to work if you fix cycles to like 30000-35000.
Speculation: DOSBox's unrealistic video memory speed together with buggy double buffering algorithms in the game.
1+1=10
Reply 10 of 16, by HunterZ
I guess harekiet already mentioned it, but ScummVM supports Broken Sword.
Reply 11 of 16, by wolf
Thanks h-a-l-9000!!! I tried setting the cycles to 35,000, and perfect! Finally I can enjoy this awesome game!!!
I do remember trying 20K and 80K, both seemed to not work. Is wierd how 35K works.
Reply 12 of 16, by Serious Callers Only
Bump. This is inconveniencing my attempt to make a no cd installation of broken sword. Is the cause known and is there any hope of being fixed or worked around?
Reply 13 of 16, by Serious Callers Only
I've niticed that the readme file speaks of this:
1. Troubleshooting guide. […]
Broken Sword requires a VESA 1.2 compatible video card with 1MB of VRAM. You
may need to install software drivers if your hardware is not VESA 1.2
compatible.
If you experience graphic corruption in the top and bottom of the display,
then you may wish to use the SAFEVIDEO option on the command line. For example,
type 'SWORD SAFEVIDEO'. This option reduces the quality of the display, but
fixes the flashing problem for older video cards.
And indeed using the switch most of the flicker vanishes... except for the cursor.
Reply 14 of 16, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Do the 35000 cycles not work or what is the problem?
1+1=10
Reply 15 of 16, by Serious Callers Only
Nope.
Reply 16 of 16, by TheDosPlace
Hi there,
First post!
To anyone still having trouble, I got the game working correctly by setting gus=false and cycles=35000. I'm using Boxer on the Mac.
[gus]
gus=false
[cpu]
core=normal
cycles=fixed 35000
^Dave from TheDosPlace
http://www.facebook.com/TheDosPlace
