Dune 2
First post, by stesla2
so i finally found my old copy of dune but now i have vista
i tried to run dosbox but after it accepts the command, nothing happens
help?
[better? :]]
Reply 1 of 4, by MiniMax
Rank Moderator
Moderator
What commands? Read the guide listed in my signature.
As you can see from this link:
http://www.dosbox.com/comp_list.php?showID=17 … search=Dune%202
Dune 2 has worked fine with DOSBox for a long time. Now, unless your machine is some kind of one-off wonder, totally different from everyone elses, what do you think is causing you problems?
Here is a free hint:
Dune 2000
and maybe a clue to way it is such a waste of time to try to get badly bungled illegal download to work.
_________________
Reply 2 of 4, by stesla2
The links for .63 seem to be down and .70 tells me that 'this program can't be run in a dos session'
Reply 3 of 4, by MiniMax
Rank Moderator
Moderator
Use 0.72.
_________________
Reply 4 of 4, by Kippesoep
Actually, that lists support as "0% supported (broken)", for 0.72, which is quite incorrect.
Stesla, you should say what it is exactly that you do before we're able to diagnose the problem. Saying it "accepts the command" without actually telling us what commands you're giving it says precisely nothing at all.
