First post, by Old Thrashbarg
I made passing mention of this in my other thread about sound cards, but decided to make a separate topic so not to derail that thread.
In the midst of messing with sound cards, a new problem arose. The PC350 I'm using suddenly started going directly into BIOS setup on bootup, with no interaction on my part. It seems to POST normally, just the standard single beep, and any changes I make in setup are retained. But, even when I save and exit, it reboots and goes straight back into BIOS setup.
I started by clearing the CMOS, checking (and replacing) the battery, verifying all the little jumper and switch settings. Reset the time and all that, saved changes, still goes into setup. Pulled out all the expansion cards and unhooked the drives, all except the floppy. It registered the changes, updated the settings, but still goes straight to setup upon boot. Tried different RAM, same thing.
The keyboard is connected through a KVM... I tried hooking it up directly and got a beep code that indicates a keyboard controller error (and no boot at all past that), and the same happens with a different keyboard. This is the strongest possibility as the source of the problem, but I don't know why it would somewhat work through a KVM. Also, with no keyboard connected at all, it will POST with a 301 keyboard error message, and will go straight into setup again.
My usual last-resort step would be to try reflashing the BIOS, and I have a floppy containing an updated BIOS, however, it won't boot from a floppy (loads setup before getting to that point). There is a BIOS recovery jumper, which I tried, and it will load from the floppy with that, bunch of noise from the floppy drive followed by the two quick high-pitched warning beeps that most flashing programs play, but I get no video signal, so I can't see how to actually do a recovery. I'm doubtful that it would do any good anyhow, since the BIOS itself doesn't seem to be corrupted.
I'm thinking I'm probably outta luck here. Any other ideas, or should I start hunting for a replacement system?
Reply 1 of 4, by GL1zdA
Have you tried an IBM newsgroup? IBM BIOSs seem to be quite verbose about issues, and IBM experts will tell you if its lethal.
getquake.gif | InfoWorld/PC Magazine Indices
Reply 2 of 4, by Old Thrashbarg
Ok, I hadn't really thought about Usenet in years, but I browsed through a bunch of groups and... they're all pretty much dead. The archives have a lot of good info, but I wouldn't hold out much hope of getting a useful reply nowadays.
Speaking of the archives, though, I found a 1999-era post where somebody had a similar machine with the same problem... there were a bunch of suggestions to try things I'd already tried, but there was never a resolution.
Reply 3 of 4, by Davros
could you tell the bios not to halt on keyboard errors ?
Reply 4 of 4, by Old Thrashbarg
That is disabled, but it's not halting on anything, anyway. All it does when it halts is bring up a warning screen detailing the problem and give options to enter setup to fix it, or reboot, or whatever.
With the keyboard through the KVM, it POSTs normally but enters setup directly afterward. No warnings whatsoever. With no keyboard, it flashes a keyboard error at the logo screen but POSTs normally otherwise, and enters setup directly afterward. With a keyboard directly attached, I get a beep code, blank screen, and nothing else.
