Virtual PC
First post, by highnrg
Forgive me if this is not the correct forum to be posting this...
I am running Virtual Pc / Win 98.
I am running Phantasmagoria 2.
The video looks horrible.
Is there anyway to optimize the video driver / settings?
What can I do here?
Reply 1 of 16, by Jorpho
In what way does it look horrible? Do you mean it's running too slowly?
It could be that video from games released back then just looks horrible compared to the video available in current games. 😉 Are you familiar with what the game looks like on real hardware?
Reply 3 of 16, by highnrg
I did some research and found out that apparently VPC uses an s3 trio video card, and it only has 8mb of ram. EW!
is there anyway to 'hack' this code? (i dont know if hack is the correct code... i basically mean 'manipulate' a .conf setting) to change it so it could load a new driver?
from what im gathering its impossible to update the VPC driver.
I am thinking about buying a gaming pc for about 600 bucks.
Reply 4 of 16, by Kippesoep
There is a setting in the .vmc file (which you can edit with a text editor as it's standard XML). Find
<vram_size type="integer">8</vram_size>
The only other setting that I've found works is 16 (32 won't work).
My site: Ramblings on mostly tech stuff.
Reply 5 of 16, by Harekiet
Rank DOSBox Author
DOSBox Author
If you just install the virtual pc addons won't it just install it's own special videocard driver that pretty much replaces the s3 one when your in windows, that does the mouse integration. Although either way 8mb should be more than enough for just regular 2d stuff
Reply 6 of 16, by Kippesoep
I had trouble with 8MB when running in 1680x1050 32bit (my regular resolution). There'd be no video memory left for DOSBox' surfaces. I'm not sure, but I don't think VMA replaces the video driver, just the mouse integration.
Reply 7 of 16, by Jorpho
Surely that was the level of technology available when Phantasmagoria 2 was released?
Reply 8 of 16, by Great Hierophant
Phantasmagoria II was released in 1996 and the high end video cards of the day were sporting 4MB.
Reply 9 of 16, by highnrg
the game runs fine. The video looks horrendous. its grainy, it's just horrible. when i played the game on my gateway back in the day, the video was 100x better.
i assure you, it's not how the video was supposed to look.
im pretty much stuck with it though, huh?
Reply 10 of 16, by batracio
Yesterday I tried Phantasmagoria: A Puzzle Of Flesh in DosBox. The FMV scenes are grainy, yes... but they don't look any worse than they did back in 1996. It's your selective memory what makes you think that the video was 100 times better back in the day, when it was not.
Anyway, if you want to improve the quality of the FMV scenes, use the XP/Vista installer and run the game in Windows native mode:
http://www.squirtthecat.com/games/phantasmago … ia_2/index.html
This new executable will enable 32-bit color depth, scaled, filtered and non-interlaced videos... but won't do any magic for a 13-year-old game.
PS: just read that you have a Mac, so ignore my message.
Reply 11 of 16, by highnrg
hey there, thank u for checking out the FMV in dosbox.
i guess when i played the game in windows 95 or 98 *i forget* back in the day, it was 32 bit enabled, (or something) even if you look the phantasmagoria videos up on youtube, they look better than they do in dosbox.
im thinking it is the 32 bit mode you speak of.
either way, i beat the game yesterday, so im over it haha
it was a pleasure playing though - i think it was probably one of the best looking FMV games during the timeframe.
Unfortunately, playing it now, i realize the gameplay was somewhat lacking, but it was still enjoyable.
cheers
Reply 12 of 16, by temptingthelure
Why would someone want to play those crappy phantasmagoria games anyways? They were garbage.
Rise of the Triad modding site!
http://rott.s4.bizhat.com
Reply 13 of 16, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
why do you need to ask crappy questions anyways? They are garbage.
Seriously, why the need to question other people's taste? If they want to play it and enjoy it, so let them. Planting flame bait is not appreciated in this forum, even if I bite 😀
Reply 14 of 16, by MiniMax
Rank Moderator
Moderator
Agreed Dominus. I hope ADDiCT also read this.
_________________
Reply 15 of 16, by temptingthelure
Why do you need to comment on the crappy nature of my question? Pointing out flamebait is just plain garbage. 😉
