General Midi in Xcom games.
Having problems with a specific game or application? Post your problems here!
Re: General Midi in Xcom games.
Postby ADDiCT » 2009-7-14 @ 19:23
Emulated memory =! host OS memory
User avatar
ADDiCT
Postby wd » 2009-7-14 @ 19:25
Erm yes, though i miss the point :)
wd
DOSBox Author
Postby h-a-l-9000 » 2009-7-14 @ 19:48
What about all the page faults, TLB clears, disk access emulations and whatnot that paging brings with it opposed to direct memory access :)
1+1=10
h-a-l-9000
DOSBox Author
Postby wd » 2009-7-14 @ 20:08
They only occur if the game likes to sweep-read the whole memory :)
wd
DOSBox Author
Postby MiniMax » 2009-7-15 @ 00:21
Qbix wrote:the first xcom seems to produce music fine at my place. when configured for general midi as music board.
Code: Select all
core=auto
cycles=auto limit 8000
cycleup=500
cycledown=20
and
memsize=32
About that memsize=32... DOSBox 0.73 is a bit wary about the wisdom in that. Gives me an "Memory sizes above 31 MB are NOT recommended." warning.
DOSBox 0.73 ReadMe | DOSBox Wiki | DOSBox 60 seconds guide | How to ask questions
_________________
Lenovo M58p | Core 2 Quad Q8400 @ 2.66 GHz | Radeon R7 240 | LG HL-DT-ST DVDRAM GH40N | Win 10 Pro
User avatar
MiniMax
Moderator
Location: Stockholm, Sweden, Europe, Earth Interests: Old games & young women
Postby ripsaw8080 » 2009-7-15 @ 00:50
XCom is one of the few games I play with DOSBox, and I've never had a problem using GM music with the default memsize. The GM music was added in the patch to version 1.4 (which was really just copying some new files from a .zip). I have the US version (aka UFO Defense), but maybe the memsize thing applies to the UK version (aka Enemy Unknown).
User avatar
ripsaw8080
DOSBox Author
Postby wd » 2009-7-15 @ 05:35
Actually what's wrong with that?
wd
DOSBox Author
Postby MiniMax » 2009-7-15 @ 09:09
Nothing wrong per se, but I want to understand what the correct memory configuration for the game is.
Out of the blue comes Qbix and says 32 MB.
Then robertmo quotes Mobygames and says 4 MB.
And finally I look in my copy of the Technical Supplement guide, and see "Required: 8 MB RAM (16 MB RAM if running under Windowsâ„¢ 95)".
So I want to know what prompted Qbix to say 32 MB when other sources, including DOSBox, seems to go against it.
_________________
User avatar
MiniMax
Moderator
Postby Qbix » 2009-7-15 @ 09:58
I merely listed the settings I run the game with, as I had not the problems the OP had.
I didn't look up the technical supplement guide to find the ideal spot of memory.
There is no specific reason why I choose 32mb for that game. 31 might have been better or not. but the game can handle the memory fine. Does 32 mb fix the midi problem ? I don't know , didn't check.
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby robertmo » 2009-7-15 @ 19:42
ripsaw8080 wrote:XCom is one of the few games I play with DOSBox, and I've never had a problem using GM music with the default memsize. The GM music was added in the patch to version 1.4 (which was really just copying some new files from a .zip). I have the US version (aka UFO Defense), but maybe the memsize thing applies to the UK version (aka Enemy Unknown).
Enemy Unknown also needs patching to version 1.4 to have GM music. I don't have any problems with GM neither with Enemy Unknown nor with UFO Defense. Both 1.4 versions doesn't start with Roland but as far as I remember also on a real computer.
User avatar
robertmo
Postby ripsaw8080 » 2009-7-15 @ 19:56
Yep, the .CAT file format changed in 1.4, and Mythos/Microprose forgot to include a new ROLAND.CAT in the update .zip file, or they didn't make a new one, and the old format causes the game to choke. I painstakingly converted the file to the new format (seriously, it was quite a process) so I could use my MT-32 with the 1.4 version.
User avatar
ripsaw8080
DOSBox Author
Postby robertmo » 2009-8-01 @ 10:32
if you still have the file it will be nice if you enclose it here so it doesn't get lost. Someone could upload it to http://www.patches-scrolls.de/ later.
User avatar
robertmo
Postby ripsaw8080 » 2009-8-01 @ 15:39
The music data in ADLIB.CAT changed a bit between versions, not just the format; so an official update of the Roland music (if it existed) might have also seen similar tweaks. I separated the music data chunks from the 1.2 format and "re-wrapped" them in the 1.4 format, therefore the music itself should be unchanged. The format was changed significantly, which made a project out of figuring out both formats: how the data chunks are organized, header format, etc.
Being a modification of a freely available file (in the update .zip), it seems OK to post. However, even though it works well, I don't know if patches-scrolls will host an unofficial patch...
xcom14_roland.zip
Roland music patch for XCom 1.4
(36.3 KiB) Downloaded 908 times
User avatar
ripsaw8080
DOSBox Author
Postby robertmo » 2009-8-01 @ 16:34
they do host unofficial setup.exe for dune 2 that allows separate configuration for sound and music, so i guess it shouldn't be a problem
User avatar
robertmo
Postby ripsaw8080 » 2009-8-01 @ 17:30
There was a similar update for Lands of Lore that allowed split music/sfx config. They were described as "beta", or "optional", but still came from Westwood, so "official" in that sense.
User avatar
ripsaw8080
DOSBox Author
Postby robertmo » 2009-8-01 @ 18:29
Just checked and indeed it was official beta for Dune 2.
User avatar
robertmo
Postby DBob » 2012-10-25 @ 16:56
I have an interesting problem with X-Com 1 and 2.
Enemy Unknown doesn't have sound at all. Nothing. No effect, and no music either. I've tried different settings of course from the setup.
TFTD has sound effects and FM music as well, but cannot initialize my external Roland SC-8820 module. All I can see, that the unit receives the midi message (blinking USB signal), and that's all. No sound played at all.
Other games which I've tried, worked.
Also tried the memsize=32 option, without success. Different mpu401 settings also didn't helped. Playing with mididevice option had no effect.
What else should I try? I'm out of options :(
DBob
Postby HunterZ » 2017-6-25 @ 06:35
ripsaw8080 wrote:The music data in ADLIB.CAT changed a bit between versions, not just the format; so an official update of the Roland music (if it existed) might have also seen similar tweaks. I separated the music data chunks from the 1.2 format and "re-wrapped" them in the 1.4 format, therefore the music itself should be unchanged. The format was changed significantly, which made a project out of figuring out both formats: how the data chunks are organized, header format, etc.
Thanks for this. It's needed to get Roland support in the Steam release of the original X-COM and I think also for OpenXcom.
Terror from the Deep works fine as-is, but I think it sounds better using General MIDI than an LA-series synth.
I think the original X-COM was composed for CM-32L/LAPC-I, as a siren sound can be heard in the very beginning of the intro that is not present with OPL or General MIDI.
User avatar
HunterZ
Postby HunterZ » 2017-6-25 @ 06:37
DBob wrote:I have an interesting problem with X-Com 1 and 2.
I know your post is 5 years old, but I thought I'd mention that TFTD now runs fine with the OpenXcom nightly build.
I'm not enjoying TFTD as much as the original X-COM, however, because it's mostly just a re-skin of the original game and because the research tree sucks.
User avatar
HunterZ
Postby Osprey » 2017-8-02 @ 02:19
HunterZ wrote:I know your post is 5 years old, but I thought I'd mention that TFTD now runs fine with the OpenXcom nightly build.
Thanks for the tip about OpenXcom. I tried it for the first time last night and am impressed. It looks and feels like the original game, but with tweaks for usability, like clicking-and-dragging on the geoscape and using the mouse wheel to zoom in/out on the geoscape and change floors in missions. I tend to prefer playing the original games, but this is a recreation that I might play.
Osprey
PreviousNext
Return to DOSBox Games/Apps
Who is online
